I ordered Ford 4" blocks they came from a lift shop so there factory take offs. I was sure to ask for the ones with a little taper to them.
When I got them there is no taper at all. I called and was told there is a slight taper but if there is its nothing you can measure.They say they will work.
The ones on my Excursion now measure 2 1/2" on the back side and 2 1/8" on the front side. The 4" blocks I got measure 3 5/8" front and back.
I also have 5" blocks I decided not to use they measure 4 1/2" front and 5" on the rear.
Will they work with no taper? It looks like all SD trucks with one piece driveshaft and Excursions need the taper or you get drive line vibrations.
I was all set to put them on today but if I am going to have problems with them I will just order the right ones from Ford. Thanks, Ken
2002 Excursion Limited 4x4.Black,BTS Trans,ATS ported shroud,AIS,SCMT,SPA gauges,Magnaflow super tuner exhaust,Bilstein shocks,V codes,Hellwig swaybar,Radius Rods,AirDog,CCV3550,JNB fuel mods, Weld EVO Renegade 16x8,Nitto Terra Grappler AT 305/70/16 E Code=NQW5,ART brakes.
You will need the tapered blocks off a F350 or you will have drive line vibrations. You could install some caster wedges from a truck alignment shop that will help but it is a lot easier to get the correct blocks to start with.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
I was duped the same way. These are for an F350 Crew Cab long box which does not have the taper. I went with Chevy 4" and they fit fine and have a taper. I had to hog out the center pin hole with a drill but that was it. These don't have the wings which is fine since you will be a long way from the bump stop. This worked great for me as I have air bags and the wing would have been in the way. I have V codes and a 1.5" add-a-leaf in the front and the 4" block in the back. I am within the service limit for the bags by 1" and they work fine hauling 10,000lbs with 500+ tounge weight. I would get the chevy blocks and be done with it.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
