FOUND OVERHEATING PROBLEM - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 06-20-2001, 12:16 AM   #1 (permalink)
My 2001 Excursion had only 1081 miles on it, 8 days old. Overheated on my wife in about a two mile strecth, then shut down completely due to overheating. Dealer said a heater hose clamp wasn't on correctly and hose came off. Problem is fixed. My concern is what damage this has caused to such a new motor? Long term, etc? I plan on having my oil anylized. Any other suggestions?
2001 Excusion PSD White/Silver, 2X, 40/20/40 bench, Bone Stock, except tint front windows and SAVE GLAMIS sticker on rear window.
sandman 36 is offline
Old 06-20-2001, 11:11 AM   #2 (permalink)
Re: FOUND OVERHEATING PROBLEM
If it shut down because it seized, I would DEMAND a new truck, or at least a new motor, not a reman. either.
Ferraris do not break down, They just sometimes stop to be admired [img]/ubbthreads/images/graemlins/grin.gif[/img]
1970 Brabham BT29 Formula B Race Car Blue/black
1999 Ferrari 355 F1 Berlinetta Red/Tan
2000 Excursion Limited 7.3 2X4 White/Grey
2002 Excursion Limited Ultra 7.3 2X4 White/Tan
2002 Mercedes CLK 320 Blue/Grey (wife's car)
Ferraridriver is offline
Old 06-21-2001, 12:10 AM   #3 (permalink)
No, it shut down because the sensors detected the overheating and automatically shut it down before it siezed.
Does anyone know at what temperature they shut down?
Old 06-22-2001, 08:49 PM   #4 (permalink)
sandman 36,
Where's our manners? Welcome to the site.
Oley
[img]images/icons/smile.gif[/img]
7.3L PSD Excursion LTD, Chestnut with Medium Parchment Int., 3.73LS, Hellwig rear anti-sway bar, Edelbrock shocks, Michelin LTX 265 M/S, PP III, Tricumulator spring set, & Sonnax modulator kit, Walker BTM, 3 pod a pillar, W/ Western Diesel gauges, Ram Air, & Turbo Brake, BD Pressureloc and Autoloc, AXD0, with LL #8, fuel pressure spring 86 PSI, Oil Guard by-pass, Firestone Ride Rite, Cyclone Power Fan
BRUTYUT is offline
Old 06-25-2001, 02:18 PM   #5 (permalink)
My Photos: (15)
You should be fine.
There have been some that have shut down due to low oil pressure.
The cure was to install oil plug and the necessary amount of oil and drive off.
With the 100k engine warrenty I would say you will be fine.
It is not like you have aluminum heads. [img]images/icons/wink.gif[/img]
99 F250 psd cc lariat 4x4
6 speed shorty
Travis is offline
Old 06-25-2001, 03:55 PM   #6 (permalink)
I did not realize that the Power Stroke had a high temperature shut down feature. Learn something new everyday.
Thanks,
John [img]images/icons/wink.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 06-25-2001, 05:05 PM   #7 (permalink)
Sandman 36,
Did the temp gauge go up gradually from normal to hot range?
Did an idiot light come on in conjunction or separate?
Wanted to verify that it was a true analog gauge through the whole range. Mine never moves from mid point regardless of the circumstance.
Also glad to note that the engine was protected by shut down.
2004 Ford Excursion 4x4 Eddie Bauer 04 6.0L B/D 10/24/03
2001 TrailBay 31BHSS W/Slideout
1964 Karmann Ghia Coupe
AXTINC is offline
