Old 12-13-2004, 09:14 AM   #1 (permalink)
Found some free springs
Can I directly swap the springs from a F-250 4X4 w/ a 6.0 PSD and crew cab short bed to my 2000 4X4 X with a 7.3 PSD? If yes, how much lift can I expect? Also if I want to add air bags for ocassional heavy towning should I order them for a F-250 or my X? Thanks in advance!!
2003 XPSD 6.0 4X4 88K miles
Xsailor1970 is offline
Old 12-13-2004, 09:19 AM   #2 (permalink)
FamilyRide's Avatar
Re: Found some free springs
Depends on what springs they are. U codes supposedly would be about 1.25"-1.3", V code a little over 1.5" and X code closer to 2" if not a little more.
Only way to know is to check the truck they came off of. Drivers door jamb there is a sticker that has several things on it, one of which says, SPR. Under that you'll see either 2 of 4 char. Like U G or UU GG. First one is the fronts second is the rears. Lot's of PSD SD's get V codes I've found. I thought U code were more common.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 12-13-2004, 01:24 PM   #3 (permalink)
Are you talking front springs only, or front and rear? The front springs are no problem, neither are the rear, but the rear blocks make a world of difference. You CANNOT use blocks from a crew cab on an Excursion. If you use blocks from a truck they must be from a regular cab or they will not have enough rake to them to retain proper driveline angle.
John
2000 Excursion Limited 4x4
265 Goodyear Wrangler MT/R's for winter
285 Bridgestone Revo's for the summer
X-codes and F-350 B-code rears
Polyurathane bushing kit
4" exhaust, intake, and gauges in the future if the price is right.
twoodballa is offline
Old 12-13-2004, 01:43 PM   #4 (permalink)
How much lift did you get with your spring swap? That is the set up I originally wanted but someone offered me free 250 springs. The "X" and 350 spring swap is going to run about $800-900. Do I just need to get a standard block from a regular cab F-250, how thick is the F-250 block?
Old 12-13-2004, 10:12 PM   #5 (permalink)
I got a full 3" inch lift in the front The rear lifted about the same, maybe a little higher. The 250 rear springs could be A code or B code. A codes are 250 only springs with ~6000lb capacity. The B code springs are 250/350 srw springs and have a capacity of 6800lbs. So you could have either A or B code rears. As far as the height of an F250 block, it depends, some came with 2" blocks and some came with 4" blocks.
Sorry, but I am afraid I added to the confusion rather than than helping out. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
John
Old 12-14-2004, 11:02 AM   #6 (permalink)
I am not sure about needing raked blocks, Edge sells flat blocks 4or5" to go with their lifts. I asked them about the lack of angle and they said that the EX doesn't need em [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is online now
Old 12-14-2004, 11:07 AM   #7 (permalink)
They are wrong, the pig has to be turned up to keep the angle correct. I used u codes and a 1.5" add a leaf and got a full 3"s that has not sagged a bit. I used a 4.5" tappered block (chevy [img]/ubbthreads/images/graemlins/frown.gif[/img]) in the rear and I have airbags also. They were within the service limit and work great...see my sig, it tows the trailers great with no sag at all. The bags don't give a huge amount of lift but I don't want that, just no sag....at all.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 12-14-2004, 12:10 PM   #8 (permalink)
BenBone's Avatar
Could you just swap the front springs for the front springs to level it out or do you have to lift the rear when you swap the U/V springs?
2004 6.0l 4WD Limted Excursion
Road Armor Stealth Bumper with Titan Guard, BFG AT 305's, AR Mojave Teflon's, Tint, Stereo, Remote Start Alarm, Strobes,MBRP Turbo Back T-409 Stainless Steel Exhaust System, AFE Pro Guard 7 Mega System, Edge Insight, Coolant Filter, ARP Studs
http://photos.thedieselstop.com/show...t=1&thecat=500
1999 Ford F250 CC LB 4x4 7.3L
DP F5, MBRP 4", AFE Satge II, DM 3 pod, 95 Gallon Transfer/Toolbox Chest, BGF AT 295's, AR Mojave Teflon's,Tint
BenBone is offline
Old 12-14-2004, 12:34 PM   #9 (permalink)
FamilyRide's Avatar
U code you should just get it leveled. V code you may need to do something wiht the rear, especially if you load her down or tow as it may put you slightly nose high.
Old 12-14-2004, 06:20 PM   #10 (permalink)
That is correct. U will level you, V will put the front slightly high, especially when towing.
John
Old 12-14-2004, 07:38 PM   #11 (permalink)
Well thats what I thought but I ordered them since they are supposed to be the experts [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/frown.gif[/img], I hope we are both wrong.
Cary
2006 Yamaha FJR1300
caryt is online now
Old 12-14-2004, 10:52 PM   #12 (permalink)
FamilyRide's Avatar
Most have gottne the 4" blocks for a Supercab SWB which have a slight wedge. It's the same chasis the Ex. is on. (not CC SWB that most people think, including myself at one point. [img]/ubbthreads/images/graemlins/laugh.gif[/img])
Old 12-15-2004, 11:53 AM   #13 (permalink)
BenBone's Avatar
Part number for the U code springs? What else do I need??
BenBone is offline
Old 12-15-2004, 12:59 PM   #14 (permalink)
FamilyRide's Avatar
See the posts above. You can't use part numbers. You need the Code only.
Also need "new" u-bolts and nuts. Don't reuse the old ones not matter how new they are.
