I havent had my 2000 PSD Excursion very long and tonight was the first time I tried to put it in four wheel drive. When I turned the switch on the dash the 4X4 light came on on the dash but nothing happened.
It didnt go into low lock either. I got out and locked in the manual hubs and the four wheel drive worked that way but the dash switch dosnt work. Any advice?
Thanks in advance.
2000 Excursion. Super Chip, 4" exhaust,K&N Filter.
As I found out the hard way, you won't get into low range unless you switch to it while in Neutral, with the brake applied.
As for 4wd, it could be a problem with your hubs, themselves, but it's most likley a vacuum problem, and a lack of vacuum will prevent the hubs from engaging. When you turn on your heater, does air blow out the defrost vents no matter where you set the dial? If so, you've got a vacuum leak or bad vacuum pump.
Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato
2001 Excursion 4x4, v-codes, Western Diesel guages, AIS with fender sleeve & zoodad, MBRP 4" exhaust, Tru-Cool Max tranny cooler, 203* thermostat, BFG AT 285/75-16's, RS9000X's, Rancho steering stabilizer, tightened steering box, Hellwig sway bar, Air-Lift springs and compressor, Draw-Tite trunnion bar WD hitch, SUVlights.com harness, PIAA driving lights with homemade harness, Cobra 25STWX radio
Most likely the vacuum pump, if the locking hubs put you in 4x4 you are fine and the pump is gone. Easy fix, $50 part. On the low lock, yes it must be in nuetral for in and out.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
Where'd you find one for $50? I think mine was $170.
Mark
I had the same problem with my X after I bought it (used). The switch on the dash operates a vacume pump on the right inner fender and also ingages the tranfercase VIA motor asm. When the switch is turned on the vacume pump will cycle for about 12 sec. Turn your switch on and then touch the pump asm and feel if is running. If it does run then I would hook up a vacume pump (Hand held unit) to the knuckle asm. and pump it and see if the hub holds a vacume ,do both sides. My guess is it won't hold vacume. If the knuckles don't hold vacume ,time for new seals on the bearing asm. and spindel asm. I did both of mine over the past winter not a big job but installing the spindal seal was a little tricky. Works great now . [img]/ubbthreads/images/graemlins/cool.gif[/img]FJF
2000 Excursion Limited 4X4, 5" Hypermax Exhaust,TS 4 Bank chip(D/P Tuner- stock,Tow,Econo,Race) A Pillar DiPricol Gauges (white face)Hellwig swaybar,Skyjacker stablizer,AFe Stage2, Slotted&cross drilled rotors,BB Turbo,Pioneer AVIC D2 <font color="RED"> *** ALL GAVE SOME, SOME GAVE ALL(FDNY 9/11/01)***
Before spending any money on a vacuum pump, inspect the vacuum lines going to the hubs. These are problematic ater a couple years as they dry out and crack or even come off in some cases as mine has twice now.
One way you can tell very easily if the vaccum pump is working is by being able to use your A/C and changing the vent positions (dash vents, windsheild vents, floor vents). It uses the same vaccum pump. To see if you have a vaccum leak put the A/C controls on A/C or Max A/C with the dash vents blowing and try putting the truck into 4Hi, if the dash vents quit blowing and it switches to the defroster vents (windsheild vents) then you have a vaccum leak.
Another thing to consider is, do you have autohubs or manual hubs installed. I had my auto-hubs replaced at the dealer under warranty and they put manual hubs on by mistake, this could be your problem too. (of course I had them switch me to the auto-hubs once I figured it out) The auto-hubs (vaccum actuated) have a grey colored strip in the handle where you twist to lock and they say "auto" and "lock". The manual hubs handle is all black and they say "free" and "lock".
Whip
'02 Ford F-150 SuperCrew FX4
fabtech 6" suspension lift, pro-comp traction bars, nfab nerf-steps, weld racing typhoon, summit mud dawg 315/75R16, flowmaster 40 series dumped, clear eyes, euro clear corners, 100w off road lights, alumistinger draw bar, manik brush guard, flex-a-lite 270 electric monster fans
