Front end clunk or rattle - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-26-2007, 09:24 PM   #16 (permalink)
Re: Front end clunk or rattle
Did you get this fixed? What did the dealer say?
2005 Excursion, PSD
Limited, 4x4 w/remote start
V Codes, rancho shocks and stabilizer
K&N CAIRS
PS Badges, SuperDuty Chrome Grill
4x2 rear glass struts
285/75/16 BFG AT
texasquail is offline
Old 02-26-2007, 10:22 PM   #17 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Feedback Score: 2 reviews
I replaced all the ball joints and both hub bearing assy. That took a good part of it away but I still had some noise. I kept looking and found the front lower shock bolts were not the correct diameter. Replaced them and it is solid, smooth and quiet!
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 02-27-2007, 01:57 AM   #18 (permalink)
Is that because the shocks had a different diameter hole or because the original owner put in smaller bolts when he changed the shocks?
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 35x12.50-17 Mickey Thompson ATZ, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120), Adrenaline HPOP, Coolant Filter, Amsoil bypass filter, Ford rear sway bar, 6 1/2" spring arch.
2000 BMW 540i, 6 speed, sport package, daily driver.
jnyost is offline
Old 03-05-2007, 12:36 AM   #19 (permalink)
Soaggydogg's Avatar
My Photos: (11)
The bolts were OEM and don't know how they worked with OEM shocks. I bought the Ex with OEM bolts and Bilsteins. For reference it has 96k today but had about 94k when I purchased.
Old 03-06-2007, 10:40 PM   #20 (permalink)
i read your post and recently had what seems to be the same concern,i thought it was all those things also,but make a long story short,try switching to 4x4 high while driving and see if the noise goes away.if it dose you can safely say you front axle bearing is shot,another way to check is to grab the front axle u-joint right behind the brake rotor and see how loose it is .i replaced the whole assembly and that noise never returned .good luck FLEX73
2000 excursion,full banks exhaust dp-tunner,edge stacker filter and gauges 305-60-16 inch tires on 16 by 10 inch rims,helwig rear sway bar,kenwood head unit and a 10 ind drop down screen totaled
NEW ex 2004 6.0 limited with pmt exhaust and a sct tunner
rsg4ever is offline
Old 03-26-2007, 09:53 PM   #21 (permalink)
Now mine has a clunk under the driver side floor. It only seems to do it when I hit a bump or am turning in a driveway. I just recently replaced the swaybar and endlink bushings with polyurethane/energy suspension bushings. I doubt they are the culprit. I am reasonably sure that I did not leave anything loose. I plan on checking the balljoints and bearing when the rain lets up. Any other suggestions?
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 08-14-2009, 02:58 AM   #22 (permalink)
Originally Posted by texasquail View Post
did you ever figure this out? My 2005 does it from second to third...a pop comes from the driver's floor board.
Any additional information on this one? Mine started the same thing, along with the incredibly annoying rattling under the driver's floorboard. Definintely something loose, reacting to bumps and turns.
jttexam is offline
Old 08-17-2009, 07:59 PM   #23 (permalink)
I too have been dealing with the mystery clunk in the floor board. It is slowly driving my to insanity. It feels like my body mount, or leaf spring mount is popping up and down under my feet, but I have checked everything and it is all tight. My next plan is to start changing out all the bushings in the front end. I am out of ideas.
2001 f-250 Superduty, crew cab, 4x4
snorton is offline
Old 08-20-2009, 04:01 PM   #24 (permalink)
UTX
I had the same floorboard creak (or pop or clunk or whatever you want to call it) and was near insanity myself. I tightened the body mount bolt several times with varying degrees of success. I finally completely replaced the body mount that's under the driver's floor (it's a 2-piece part, Ford calls them "isolators") and it's wonderfully silent now. Hope that helps.
UTX is offline
Old 08-20-2009, 11:59 PM   #25 (permalink)
Pharmer's Avatar
The body mount seems to be more of problem with the 2000MY. I had that problem with my 2000.
03 Excursion Eddie Bauer 4WD 7.3L, 265 REVOS, U's and F's(mod), 3rd row headrests
68 Cougar xr7 390GT, 05 E320 CDI http://www.supermotors.net/vehicles/registry/3724
Pharmer is offline
Old 08-21-2009, 03:59 PM   #26 (permalink)
I will give that a shot
snorton is offline
Old 08-23-2009, 09:45 PM   #27 (permalink)
MotionMan's Avatar
another small clunk is the waste gate opening when you start it, its very mild but it is a clunk I hear. Its on the pass side.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 11-29-2009, 03:16 PM   #28 (permalink)
I had front end rattle. I traced it to the front lower shock mounting bolts. I simply grabbed the shock and tried to twist it and was able to feel the movement. They have a tapered shaft and even though tight the shock can wear a little and rattle. i replaced the bolt and all is well.
Excursion 2004 4X4 Limited - PUEBLO GOLD - 6.0L T-C Diesel - 5-Spd Auto Trans -AM/FM Sterio In-Dash 6-CD - Rear Seat Entertainment - DVD - 2nd Row -Dual Bucket Seats - PWR HTD T-T Mirrors - 3.73LS Axle - T-Case Skid Plate - Thule Top Rack - SC Tuner
Veh. Built 7/16/03 Eng. Build date 6/27/03 by International - Purchase Date 9/1/03 Milage on date 6/9/04 = 15,000 11/15/04 = 26,890 4/19/05 = 35,639 12/12/05 = 49,810 8/29/06 = 63,750 3/27/08= 100,003 Rancho 9000 shocks F & R.
It is hard to take travel serious when every time you leave home you take an Excursion !
Mesu
mesu is offline
Old 08-02-2010, 03:20 AM   #29 (permalink)
i just recently replaced my driver side bearing/hub assem. and put new warn locking hubs on both sides if my 99 1/2 super duty deisel. i now knowtice a light, clink sound when im driving slow on the pavement, and when im driving all the time in the woods. could the seal/ bearing on my axle housong be going bad? or my u-joint? IDK
Amarica or go HOME! is offline
Old 03-24-2011, 02:27 AM   #30 (permalink)
Track Bar is torqued at around 380# and will require you to have it on a lift with a cheater. Check the bushings at the end of the leaf where the leaf and shackle meet. I had the same clunk. The leaf slid over making metal to metal contact with the shackle causing a clunk right under the driver’s seat. Bought them online and had a shop press them in as well as an alignment.
Pile291 is offline
