Re: Front end lift question
Maybe not a lot of help, but here it goes.
Yes, you can lift the front to offset the droop. Call a spring shop in your area and they can help or give you suggestions on how to do it.
I've done it on other types of vehicles, but not the X. I also have a 2WD so I'm not really sure how the front end is set-up on the 4X4 X.
If it's springs are the Spring under set-up? In which case I think you will need to just add a taller shackle, but make sure it's beefy enough to handle all the front end weight.
If it a spring over set-up, then you can add a helper leef to get the correct height.
Hope this helps.
Rob
