Going to change out my front grill, what is the easiest way to remove the bottom tabs? I can get the 4 screws off and gently bend the front grill forward, but not sure of the tabs at the bottom? Thanks in advance
Jay
2000 "X", Date of Manufacture 2/00=No PMR's!, AIS, IssPro Triple A-Pillar Gauge Pod, Zoodad Mod, CCV Mod, DP 4 Position Chip (Stock, 40 hp tow, 60 hp tow, and 80 hp econo), Bilsteins, Hellwig Rear Sway Bar, Fumoto Valve, Updated Front Headlights, ITP HX Mod, Dieselsite Coolant Filter, Magnefine Tranny Filter, FTVB, PML Tranny Pan, Magnaflow 4" Turbo Back Exhaust, Mag Hy-Tec Differential Cover, Aeroturbine, Thule Cargo rack.....and a disease to keep on adding!
Small flat head screwdriver, pry up on the tabs while gently pulling out on the grille, they'll come right out.
2001 Excursion 4x4 Limited v10, Estate green, 4.30 LS
Bull bar, 150w KC Daylighters, clear corners, bed liner on bumpers and lower trim, zoodad mod, v-code front springs, acetoned emblems, deleted running boards, in channel vent visors, 285/75/16s, all green in-cab lights changed to orange, gutted cat and SuperTrapp muffler w/10 discs exiting at the diff, dome light override switch, 3 ga pillar mount Pics!!
Defintely post up anytime JGH and join in on any of the threads,there's always something going on [img]/ubbthreads/images/graemlins/smile.gif[/img]
-BILL
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
