I have had over 47 Ford trucks and sooner or later the pinion seal will start to leak. its not too hard for the dealer to replace but it does take a little knowledge of how to set the backlash on the rear end, my dealer did a cuople of trucks and I think it only took less then 1.5 hours
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
Had mine replaced a while back at the stealer...was under $200 out the door...I think around $180.00. You have the labor, the seal, some new nuts or a new nut I think and rear diff. fluid to top it back off.
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel! http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Had mine replaced last week. I was kind of miffed with the dealer because I found the leak a couple of weeks after I had taken it in for it's 30K mile service. Not only did they not find the leak, they forgot to balance and rotate the tires. They probably forgot to do a whole bunch of other things too. At any rate, I took it in and complained. They say that they gave me a free oil change, along with balanced/rotated tires, and fixed the leak...all for free. Of course, I no longer trust that they did anything unless I can check it myself. I already went back and retorqued my lugs.
