Front Spring Part # vs Code - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 04-16-2009, 11:08 AM   #1 (permalink)
therabbittree's Avatar
Ok, I've just been searching here for spring s codes that match these part #'s for front springs.
F81AADD and #RPN1128 was stamped under the other #.
I am hoping these are snow plow prep springs x codes or similar, as they came froma 1999 F250 XL 4x4 work truck with 6spd and v10 and plow.
I have done sesarches read tons of threads in the searchs for front springs, spring codes, part # etc etc. I also have a 2 vol set of the 2000 ford superduty work shop manual and I can't find different spring part #s in the manual either. The door sticker was removed on this truck in the junk yard..so the sticker is no help. I have the Vin #1FTNF21S5XEA96298
Truck had 79k on it
Here are pictures.
snow plow ? spring and stock 5.4 gasser excursion spring
part # front springs
are the plastic shim / spacers that go on thearound the center bolt available separately?
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline
Old 04-16-2009, 03:26 PM   #2 (permalink)
My Photos: (5)
My X codes are stamped 3034AFA if that helps any
02 Excursion Limited 4x4, 7.3L Diesel, Edge Juice w/Attitude, X/B Springs, 285s
bostonX73 is offline
Old 04-16-2009, 08:43 PM   #3 (permalink)
X Codes..F81A-5310-AFA, stamped #3034AFA, Suffix AHD.
W Codes.. ? - ? - ? , stamped # ? , Suffix AGD.
V Codes..2C3Z-5310-HA, stamped #3C34ADA, Suffix AFD.
U Codes..2C3Z-5310-GA, stamped #2C34ACB, Suffix AED.
T Codes.. ? - ? - ? , stamped #F81AADD, Suffix ADD.
S Codes.. ? - ? - ? , stamped # ? , Suffix ACD.
H Codes.. ? - ? - ? , stamped # ? , Suffix HA.
G Codes.. ? - ? - ? , stamped # ? , Suffix GA.
D Codes.. ? - ? - ? , stamped # ? , Suffix DA.
C Codes.. ? - ? - ? , stamped # ? , Suffix CA.
B Codes.. ? - ? - ? , stamped # ? , Suffix BA.
Old 04-20-2009, 02:45 PM   #4 (permalink)
can any one with the V or u codes look and see what their stamped # on the springs is please?.. I need to know if I wasted my $ on these front springs. If so I'm just gonna order new ones from ford..
Thanks,
Deo
Old 04-23-2009, 08:26 AM   #5 (permalink)
ANY ONE know the stamped #s from a set of v codes or u codes?.. I'm ready to junk these springs and buy new ones at the dealer.. any help is appreciated.
Deo
Old 04-23-2009, 12:52 PM   #6 (permalink)
BadDogPSD's Avatar
Deo
I have V codes on my truck. I'll post the code in the morning (don't have my truck with me today)
1997 F250 4x4 Crew Cab PSD; Modded H2E, FFD Stage 2's, CPR Fuel, SRP1, ARP studs, Comp 910's, DI pushrods, Dana 60; Sky RSK w/SD springs.
BadDogPSD is offline
Old 04-23-2009, 02:53 PM   #7 (permalink)
Thumbs up
Thanks!!!
Old 04-23-2009, 04:27 PM   #8 (permalink)
BadDogPSD's Avatar
Made it home earlier than expected.
The numbers stamped on the bottom of my front springs are-
3 C34 ADA
R 266 3
These were out of a 2003 F350 CC 4x4 and the spring code on the door
was V. Hope it helps!
Old 04-23-2009, 05:15 PM   #9 (permalink)
wel i updated my part # and stamped # list oh well ..still no match for my mystery springs ..argh ..oh well im probably gonna buy new ones I guess and sell my junk yard ones etc.. looks like the truck i got thme from at the junk yard that had a snowplow didn't have a factory plow prep packake..oh well
Old 04-23-2009, 06:19 PM   #10 (permalink)
BadDogPSD's Avatar
I don't know why Ford changed the numbers around so much from year-to-year. It's very likely that your junk yard springs are V codes. The one thing that seems to be consistent in the 99-04 models was the V codes all seem to have had 'AD' in the stamped numbers, and the 99 model years were split like that on the ends. You may want to send a pm to Caryt and Smokeywren, they both know quite a bit about springs and might be able to help.
Old 04-23-2009, 08:32 PM   #11 (permalink)
yeah I am not sure why they have two different part # s for something the stamped # and the part # .. kinda confusing.. I'm new to fords..vw and dodge don't do that. haha.
I did PM Caryt regarding the stamped # ..hopefully your right and they are early '99 V codes. ha.. It would save me some time and $ etc. I did take apart the B Code set and modified them tonight..it went pretty easy the G code center bolt worked nice, as the B code center bolt had to be cut off it would not loosen up argh..
Deo
Old 04-23-2009, 08:52 PM   #12 (permalink)
boertje's Avatar
My Photos: (29)
Check my sig for the V code numbers.
2001 VW NB TDI speed.
SOLD: '02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads, IH CPS part # 1826899C93 (original CPS).
boertje is offline
Old 04-23-2009, 09:05 PM   #13 (permalink)
thanks .. i have you # 's .. any idea on my mystery spring ..maybe aearly v code?..stamped #F81AADD
Old 04-27-2009, 05:27 PM   #14 (permalink)
I finally had time to check my U code fronts (at least that what I think they are). They supposedly are from a 2003 F250, with U on the door code.
2C34ACB
RPN2452
gabeyd is offline
Old 04-28-2009, 06:54 PM   #15 (permalink)
thanks I updated my part # list above next is w codes ha and these mystery springs, I have a free set of V codes waiting in texas fro me ha.. texas to ny shipping is 120 bucks argh..ha..debating doing those or ? buying new x or v's
I've noticed looking at several v codes on here and in classified forums that they have a l2 leave pack that sit togtehr..not sure what springs sit apart like th emystery spring si have here?.. any idea ..I've looked at some trucks at work and most have v codes..and have the leaves together no spaced open etc
Deo
