My '00 Ex. was involved with a head on accident that shoved everything to the passenger side. We had the vehicle fixed instead of totalling it. The frame had to be straightened and all, and I believe that the frame was close to right on. So, I picked up the vehicle and was looking at it the other day and noticed the passenger side tire sticks past the side of the truck more than the driver's side tire. I drove the truck straight in fresh snow and found that the front tires drive 2.5-3 inches off to the passenger's side. The dealership is saying that they only do things to 2 inches accuracy, and so this is acceptable. Are there some kind of alignment pins I can check to see if the axle has slid or anything? And is this acceptable workmanship?
'01 X with 4" lift and 35's, Diablosport Predator, no upgrade intake or exhaust or gauges, diesel
'00 X with everything stock except Firestone replacement tires, diesel
'00 F-350 Super Cab, diesel
'88 F-350 7.3 diesel, crew cab
'87 F-350 6.9 diesel, reg cab
2-3" I'd get a second and maybe third opinion as I wouldn't accept it till it's within Ford factory specs.
Bill
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
The Service Manager said that the Ford spec is 2 inches (supposedly). Since everything on this Ex. is stock '00, is it just the alignment that is out of wack 2-3 inches and can be fixed easily, or not?
a reputable alignment shop should be able to answer that as it could be several different things. but i'm w/ Bill i wouldn't except it until i know what, why, and if it can be fixed. i didn't like mine when it was only slightly off, 2-3" would drive me up the wall.
-Chris
2001 4x4 Limited X PSD
Chromed SuperDuty grille, HeloMaxx8 17x9,BFG315/70/17,Edge 3' leveling,
Hellwig rear sway bar, AIS intake, PowerElbow, 4" Monster Exhaust, Aeroturbine,
Banks Big Head actuator, Banks Compressor Wheel, Banks Transcommand,
Tag's I and II (and love'm), Hx crossover, 2003 headlights, Bilstien shocks, Rancho stearing stabilizer,
203t-stat and billet housing, and Edge Evolution, 24" PIAA wipers, intake heater delete,
Garmin Street Pilot 2610 GPS
<font color="red"> New BTS trans</font><font color="#OOFFOO"> LANDYOT radius rods</font>
"If you don't get everything that you want, be thankful of the everything that you don't want that you don't get !!!"
This is the Ford spec for dog tracking which is a lot in my mind. I would go to a good frame shop or body shop and avoid dealers body shops for this kind of work, especially on trucks.
Dogtracking — F-250, F-350, F-450, F-550, Excursion
Dogtracking — Maximum (Centerline of front tires compared to centerline of rear tires) 30 mm (1.2 in)
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
I had the same situation with my Bronco after a collision. The frame shop said the frame was diamonded. It was fixed for about $450 back in 1995. I had no problems after that until I rolled it two years ago [img]/ubbthreads/images/graemlins/sick.gif[/img]
Good luck
. “And to check for diamonding, you should crisscross measure from one corner to the opposite corner and then compare that measurement with the other side. The tolerance for that measurement should be no more than ¼ inch, though I like to see even less.”
2002 F350 CC SB 2WD mostly stock
