I am needing new rotors at least on the front. I am having really bad vibrations when I step on the brakes. I had been thinking ART however I came across www.frozenrotors.com and I can get a complete set of gas slotted frozen rotors for a lot less than ART. Plus I could have them cross drilled as well and still be less than ART. I already had the pads done about 10K about when I had the rotors turned...Already bad.
I was wondering what anyone thought of www.frozenrotors.com..What I thought was interesting is that they both use the same brake pads "Performance Friction"...
Ken
Ken Fanta
2000X PSD Bilsteins, Rear Helliwig, Rancho Steering Stablizer, Dual remote bypass oil filter, K&N air filter
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
We have been selling the Power Slot rotors and Hawk Pads with great success. All the severe use drilled rotors I have seen eventually crack, sometimes they even lose chunks which can be a big problem etc. They also have a cyro frozen product for a few bucks more but we haven't found it to be necessary so far.
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
Mark @ DPPI
I am happy with my ART's on all 4 corners, but that was before the price went up. I also would be concerned about cross drilling. That really is where cracks generate from on any metal object. The slots are more than adequate in my opinion for gassing off. My braking is easily 20% less distance.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
My next question is do I replace all four? They took the tires off and definately the front rotors are done for. According to DIS (diesel injection service) where I get all my work done the fronts do about 80 - 90% of the braking. So if for not I can save a little money I might as well?
What are the thoughts of the public...
Ken Fanta
I have to do the brakes on mine and will go the ART route. I have heard nothing but good about them except for one member here that had problems. I think it was pad related though. I should have them in a week or 2 I hope.
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- TN BB 1.0 Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner PCM QLJ5/PMT1 combo, Edge Juice/Attitude for gauges.
