I dropped my tank last night to do the Harpoon mod (I think that what it's called) and when I reach inside to feel the vent tube it only stuck out about 1 1/2" - I thought most everyone here that has done this said they had about 4" of vent tube sticking into tank.
Anyway, I cut off what I could using the pvc cutters and cut off about 1" - so there is still about 1/2" sticking into tank.
vc
2002 LTD 4X4,Bi-Xenon HID's,Amsoil Dual Remote,Wicked Wheel,under dash 3 gauge pod(Isspro's), 203 t-stat,aluminum t-stat housing,evans coolant,TRU-COOL MAX tranny cooler,external tranny filter,Western Diesel RamAir intake,Edge Evolution tow tune, Edelbrock IAS rear shocks,Landyot's Radius Rods,5 new Pirelli Scorpions courtesy of Ford.
Yup, that jives with what mine has. I don't think there's as much of an issue with the foaming on an X as there is on the trucks because the tanks is so DEEP. The truck tanks tend to be longer and shallower.
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
vc
Yep. I'd have told you if you'd have asked.
I used to list a "factory" harpoon in my sig. but recently dropped it because I ran out of space to add new things.
I was going to do this mod in my X this weekend. I have problems filling the tank up. After I get foam I can still put in approx. 5 gallons afterwards (which takes longer than the 37+ gallons preceding it). Drives me bonkers. Not that I have bad range without those last 5 gals.
I'll let you know about mine. Maybe the factory messed up and put a longer vent tube in mine. I seem to have the odd-ball X anyways. No factory sway bar, etc...
Dak
Previous Owner of a 2004 Diesel Excursion and 2005 Diesel F250.
jschira,
I guess you'll have to abbreviate alot of those items in your signature and make some room for more - that is if you can find anything else to do to your X [img]/ubbthreads/images/graemlins/wink.gif[/img]
To whoever else cares for an update, I went and topped off this afternoon. Now before doing this mod I could pump fast until the last 7 gallons. This afternoon I could pump fast all but the last 2 gallons. The last 2 were slow, but 2 slow is 3 times faster than 7 slow.
So there you have it.
vc
Thanks for update. I'm going on your expereince that it is worth it for me to 'poon the tank this weekend.
I almost got in trouble with my wife when I told her I was doing poon tank this weekend.... I learned not to abbreviate as much when speaking to her as I guess she heard something else.
jschira,
How close to full do you get with your "factory" harpoon? Sounds like they are all a little different.
On my '04 X I get 3.5 gallons in after it shuts off. Not going to go through the trouble of dropping the tank as the range I get with 40 plus gallons is plenty. I only squeezed in the 3.5 gallons because I was curious how much room was left after reading the "poon" posts.
04/04 PSD X 4X4, Oxford White EB, October '03 build, all options except 2nd row captain's chairs and chrome step tubes, stock drivetrain, no flashes (still have quiet idle and original tow/haul), Donahoe 4.5" Spring Hanger Lift, High Angle Driveline CV Driveshaft, American Racing 17X9 Chrome Chamber Rims, Toyo 35X12.5R17 Open Country M/T's, PSD Badges, Yakima MegaWarrior roof rack with extension and King Cobra bike carriers mounted outboard, AMP Research Power Retracting Running Boards, Brakesmart Controller, Radius Rods, Firestone air springs with on board compressor, C-Bet'r mirrors, Marinco block heater plug in front bumper. Towing 28 ft. Sunline TT with slide room (7500#).
2001 Dodge RAM 1500 Quad Cab, Intense Blue/Silver two-tone, 4X4, 360, auto, 4.10 gears, Off Road Package, Daystar 2" front lift, 285/75R17 MT/R's, K&N Intake, Gibson stainless cat back, Line X spray in bed liner, Firestone air bags w/ on board compressor. Boss 7'6" plow.
DFW62,
if you are getting to within 3.5 gallons I would NOT drop the tank for that.
Incidentally, the vent on the X tanks are not at the highest point on the tanks roof. I think if I would have been able to shave the vent tube flush to the top, I still would not be able to fast pump every last gallon because of this. On my tank the top is not a flat top. It has several small humps that rise above where the vent is located, and this will always trap a little air and slow down the last gallon or two.
vc
vc
You also get a lot of foam. The foam will back up the filler neck first and should shut off the pump. You will always have to let the foam settle a bit before you can fill it all the way up. With diesel fuel, I don't think that you are ever going to be able to shoot it right to the top of the filler neck like you can with gas.
I really don't know how fast I can fill mine. A little embarassing to admit, but with only 1100 miles on the X (long story), I've never filled it up. The dealer filled it up when I bought it (November 2002) and that tank last 6-9 months. I only put 3-4 gallons in at a time because mostly, the X sits and I don't want old fuel it it.
I changed the oil a couple of weeks ago simply because I had the time, and with a July 14, 2002, engine build date, that factory oil was getting a little stale.
That's why all the mods. I've got to do something with it.
