Anyone put the coil over kit on their excursion. Looking for some feed back
05 Excursion/ Full Traction front coil-over conversion w/Fox shocks/Donahoe Racing 6" spings in back/Weld evo 16x8 wheels 315 BFGs/Fumoto/Amsoil with bypass filter/AirLift rear bags/
i am going to do it but the cost is pretty high. just the lift is about 2600 and then you have to buy the coilovers seperate from the company of choice. so it will be high in price but the ride is suppsed to be night and day. i need a custom one made by them for my dynatrac upgrade kit i have( i have the combo kit).
99.5 F350XLT CC LB 4X4, 8" SUPERLIFT, 17X10 WELD SANDSTORMS, 40/13.50X17 GOODYAER MT/R, AIR INTAKE HEATER PLUG, AFE STAGE II, WHICKED WHEEL,JOHN WOODS TANNY STAGE II, DYNATRAC SUPER DUTY COMBO KIT, AGR ROCK RAM SYSTEM, 6 POSITON CHIP WITH JODY TIPTON BURNS, HOG 4" TURBO BACK EXHAUST, 4.56 GEARS FRONT AND BACK WITH ARB AIR LOCKERS, ARB AIR COMPRESSOR
ECLIPSE 5495, SOUNDSTREAM CONTINUUM, 2 PAIRS ECLIPSE SC8365 3WAY COMPONENTS, ECLIPSE SW9102 SUB. 10" FLIP DOWN SCREEN, PS2, AND LOTS MORE! truck pics
2002 EXCURSION LIMITED 7.3TDI, AFE STAGE II, DIPRICOL GAUGES, DP TUNER F5 CHIP, 4" HOG PERFORMANCE TURBO BACK EXHAUST
2005 VOLKSWAGON JETTA 1.9TDI, KERMA QLOADER, 100 HP AND 40+MPG IF I AM GOOD.
Will the kit not work with non unit bearing hubs.I was planning to add those also down the road.
the dynatrac bearings kits come in two seperate deals. one that converts what you have to the changeable bearings. the second one converts everything from stub axles out including knuckles. this kit also does a crossover steering and moves the panrod bar(track bar) to higher ground and with less of an angle. so the second kit involves full traction to make a one off bracket for this already upgraded system.
