Funny smell from air conditioner - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-02-2005, 01:18 PM Thread Starter
Ok the other day my wife came in from driving the X and said it smelled like trout. Since I am not a fisherman wasnt sure where the smell would be coming from. Then I went out and turned the A/C on and the smell coming from the vents did indeed smell like fish. I keep my garaged all the time and do not have signs of rodants or anything so I tried to eliminate anything that might have crawled up in there and died. I dont know. Has anyone had a funny smell come from the air blowing out the vents and have had any luck getting the smell removed? I will tried some kind of air freshener but wondered if something more efficient would do other than hanging a freshener from the mirror. Maybe there is something I can put down in the fan housing or something. Any thoughts would be greatly appreciated.
2000 PSD Excursion Limited - PowerSlots Cryo Treated Rotors - CCV Mod - Zoodad Mod - DIY Tymar
hobhancock is offline
post #2 of 5 (permalink) Old 08-02-2005, 11:24 PM
FamilyRide's Avatar
Re: Funny smell from air conditioner
The A/C in the Ex. seems to get musty pretty easily. My Expedition did some, but not this early and not as bad. The more it runs the more is clears out but I don't like getting that nasty smell blown in my face.
I try to run the fan without the comp. on before shutting down which works in most cars, but not this one.
Ford supposedly has a really good freshener that kills all the stinky crap in the vents. I'm sure others may have other suggestions.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 5 (permalink) Old 08-03-2005, 08:37 AM
I read in my 04 Excursion manuel to leave the vents open, that is turn off the A/C and just go to outside air (ie heater). This will help with the odor. On mine, I have tried it and yes it does help. My X sits for days/weeks at a time in the driveway....which reminds me, I need to go change it from A/C to just vents...been sitting now for about a week.
luckeyd is offline
post #4 of 5 (permalink) Old 08-04-2005, 11:25 PM
remove the fan under the hood and spray simple green on the condensor...let sit a few and then rinse with water hose..(yes it will drain out the bottom)..it'll smell good and will blow stronger and colder afterwards..
Tom [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
CTFD
Contact Info..
512-762-1485
LATE 1999 F350 CC Dually 2WD,4" stainless Magnaflow.Highly Modified GT38 Turbo
DP-Tuner 4 Pos. chip, PS2000,4" intake with fleetguard filter ,Suncoast Tranny With Triple disc T/C, Lunar Guages
12 Speaker 770 watt Fosgate,Sony and Infinity system with (((XM))), Stull Billet,BFG's and acetoned badges.ART rotors, More to come. 8100lbs.
1/4 mile 14.80 @ 94.24 MPH
2000 Limited 4X4 Excursion Toreador red and tan,(((XM)))Rancho RSX's, Hellwig anti sway,V codes on front, skyjacker dual stabilizer, Edge Evolution AFE with PG7, Eddins House of Diesel 4" Exhaust with Polished 5" tip, Suncoast tranny with triple lock, 15.1" DVD monitor,now rolling Akuza Bounce 20's w/ Toyo 305/55/20 AT's
EXCAV8TER is offline
post #5 of 5 (permalink) Old 08-06-2005, 12:02 PM
Not likely the case...but once I had a male cat "spray" in the engine compartment in my car (many years ago). The smell came through the vents so that I couldn't use the AC or heater (oh man, the heater was MUCH worse). I have to say, it was a HORRIBLE smell and quite revolting.
If you were parked somewhere where there was a cat...you just never know. I hope that this isn't the case for you though, as it took MONTHS for that smell to go away!
Tailgate
1) 2000 Excursion PSD Ltd, 4x2, Dark Green, DP Tuner, Autometer gauges, AIS w/ Zoodad, ITP HP/X, Walker BTM, Dahl 100, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil Bypass / fluids, Hutch Mod
2) 2000 Excursion PSD Ltd, 4x2, Chestnut, BTS Tranny, DI 4-Way Chip, AutoMeter CF gauges, AFE intake, Magnaflow 4" turbo back, Wicked Wheel, HP/X Crossover, KYB shocks, Hellwig rear swaybar
3) 99.5 F250 CC SB PSD XLT, 4x2, 3.73 LS, aFe Stage 1 intake, Zoodad mod, 4" turbo back exhaust, Amsoil
Tailgate is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
