Old 01-28-2006, 10:48 PM   #1 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Gadget space and location... Brake controller, Chip, switches, Gauge location
2003 Ex 7.3 - Mom's ride
Dad is trying to figure out what should go where. I am a few states away trying to help.
He has the cb and apcm mounted in a waffle grid on the tranny hump so that space it gone and has the Prodigy in the cubby hole.
We need room for chip switch and 5 rocker switches (hd flasher, tail flasher, fog lights, air comp, backup lights). And TTM if he puts that on a kill switch. Problem being it is climate controlled so the right leg of steering column doesn't offer switch space.
He is thinking of Pyro, boost, and tranny in the overhead the rearview mirror mount or pillar mount. The air pressure gauge is probably going beside the cb/apcm on a waffle grid mount he got from Galls.
Where did you tuck all your stuff away?
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 01-30-2006, 06:21 PM   #2 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Re: Gadget space and location... Brake controller, Chip, switches, Gauge location
50 people have viewed this and not a single one of you have a switch in your Ex?
Old 01-30-2006, 07:24 PM   #3 (permalink)
I will be needing to add a few to my new X
I was looking at the strip below the Head light switch above the CJB cover.
Anyone know if this is a separate piece or part of the dash?
If this 1.5 by 8" strip (guessing on Dims here) could be removed and switches fit to it it would be great. I was thinking those OEM style rockers available at most auto stores, they come with and w/o pilot lights and so on.
If you messed up or wanted a piece without openings you could order one.
On second thought order one so you have it then modify new or old one since the newest dash you can have is an 04. [img]/ubbthreads/images/graemlins/depressed.gif[/img]
They would be out of the way and not noticable for the most part.
Just a thought
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 01-31-2006, 06:03 PM   #4 (permalink)
OK looked at it last night and the Manual again today
it does not look like that is a separate part only the side pannel above it with the little air/side window defrost slots in it come off to access the left side dash assembly bolts.
However I have not removed the above and the CJB cover to check.
Bruce
Old 02-01-2006, 08:24 PM   #5 (permalink)
clamgulch's Avatar
I have 4 rocker switches to the immediate right of the steering wheel on the bulged out area just above the under-dash access panel.
I'm moving my brake controller to the front of the center console because when mounted in the dash, it is too far away in an emergency to clamp on just the trailer brakes [img]/ubbthreads/images/graemlins/eek.gif[/img]...Speaking from expensive experience. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 02-01-2006, 10:04 PM   #6 (permalink)
OK that is the same as I was talking about except on the left.
Does this part come off? or did you just put the switches in in place?
Bruce
Old 02-01-2006, 10:28 PM   #7 (permalink)
MotionMan's Avatar
The best place for the brake is the indent just to the right of the wheel, I can reach it, yea it is a little awkward but it is doable, you just have to be ready and I am 6.1 and have long arms. I have a light switch to the left but it is surface mounted. No others yet.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 02-02-2006, 08:32 AM   #8 (permalink)
ClamGulch -
When you say mounted in the dash" do you mean mounted in the cubby?
If so, it seems that everyone has a different place that is comfortable for them.
2005 EXCURSION!! XLT V10 Silver Purchased 10/8/05 19920 Miles.
Heated tow mirrors, Hood/window deflector,Ford rubber mats, Firestone bags/air source kit, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Curt front reciever, 6 disk Visteon stereo, 6 disk changer in console, X-3 AIC, door lights,OEM Fog mod, volt/tran temp gauges,skid plate.
housedad is offline
Old 02-02-2006, 08:34 AM   #9 (permalink)
I'm going to be inspecting my dash carefully this morning, in prep for installing the switches. this means I will be taking off the fuse panel, ashtray/cupholders, and anything else that I can remove that takes less than 10 screws.
If you want me to look at something for you, let me know. I'm hoping that I can get the cluster off easily.
housedad is offline
Old 02-02-2006, 07:46 PM   #10 (permalink)
06Clone's Avatar
My Photos: (5)
Yes, take a look see and report back exactly where those 4 user servicable wires are that terminate rignt over the engine fuse box. Also if you can, find out where that overdrive wire is that I keep inadevertantly turninig off on the shifter. I want to delete it and put in on a rocker on that lower dash bump Steve talked about. I have this cute little carbon fiber knob (matches my interior trim package) that will replace that plastic piece a doodoo (replaced twice) that keeps coming off the end of the shifter.
Thanks, doug
06Clone is offline
Old 02-02-2006, 07:58 PM   #11 (permalink)
Soaggydogg's Avatar
My Photos: (11)
clamgulch, sent you an email with picture of my problem. Anyone else want to see it let me know.
Again, I have climate control so there is stuff in the way on the right side of wheel that other models may not have.
I suggested to remove that cupholder tray and have someone make an aluminum or stainless piece to fit there and then mount switches in it. Dad said, No, he wants the cupholder tray to stay for now. I also want it gone since my cb and my apcm are underneath that cupholder and if something spills...
Old 02-03-2006, 08:44 AM   #12 (permalink)
HOOOOOLD EVERYTHING!!!
Looky what I just found!!!!
http://www.trademotion.com/sfimages/...Image36416.jpg
http://www.trademotion.com/partlocat...catalogid=3655
And it comes with a cubby "storage bin for the extra space.
Now you too can have Ford Upfitter switches!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
It is a kit made by ford, so your local Ford dealer should be able to get one, also.
Here is a forum thread I found: http://[censored].net/forums/printthread.php?s=c5d6d6dc8faaf6383dad98cdd8e21f16 &threadid=3542
And install instructions that someone made: http://www.[censored].net/f250/upfitter/upfitter.htm
This solves a lot of problems.
housedad is offline
Old 02-03-2006, 09:31 AM   #13 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Gee, thanks.
What about my 2003 and apparently 2004's are different also?
Old 02-03-2006, 10:02 AM   #14 (permalink)
Crud...
I was a hoping it would work. The o5 superduty das is different from the Excursion dash. The maker is sending me the measurements of the unit to see if the dash can be drill/modified to fit.
It sucks to get all excited and then find out you're wrong...
housedad is offline
Old 02-03-2006, 07:16 PM   #15 (permalink)
In my 03 I put the cip switch in the sunglass compartment. [img]/ubbthreads/images/graemlins/cool.gif[/img]
2006 F-350 Amarillo 4X4,SRW,CC,LB, yellow loaded to the hilt and 20" rims 2003 F250 6.0L, Crew Cab,Lariat,FX4,SRW,Oxford white over Arizona Baige.
HeathKnight is offline
