Re: Gas fill neck
and to help out I copied it here:
Take the cap off and look to see if there is a plate with a hole in it
for the nozzle.
If so, you can cut it out with a dremmel.
Remove 3 bolts holding the filler pipe and
unclamp from the rubber hose leading to the tank.
Take it out and cut out the plate so its just one big hole.
Wash and rinse for any debris.
Reinstall and now the truckers nozzles will fit.
