Re: Gauges and options
Bassman,
3gauges-Folks are talking about a 3 gauge system such as a pyrometer to monitor the EGT exhaust gas temp of the engine, Boost gauge to monitor the PSI pounds per square inch of turbo boost, and a Transmission temperature gauge for monitoring the transmission fluid temperature.
TTM- This is a "Black Box' item to let the truck continue to run even after you have left it locked up so it cools the turbo seals and bearings after a hard run or a quick exit from the truck. The Pyrometer mentioned above does the same thing if you watch it when you park the truck. I always make sure our "PRE" turbo mounted pryo is at or below 300 degrees before I shut the truck off.
Apcm- This is a Ford or aftermarket device that idles the truck at elevated rpms if you leave the truck running alot when you're on the phone or maybe taking a nap. If you never leave the truck idling for more than 10 minutes don't worry about it.
Isspro gaughes this is a brand of gauges just like our Western Diesel Performance line of gauges. Just like Ford is a brand.
DIS gauges- This is a place and a good one too to buy accessories and parts for your truck, we like to think of ourselves as a good place too!
Apillar- this is the mounting location most folks use to mount their gauges . It's a plastic overlay that fits on the A pillar of the truck. That's the area to the far left of the front windshield like the one on the far left that has a grab handle on it. it has a location for one to three gauges in it depending on what you decide you want to have. Hope this answers you needs if we can help call us at 888-621-4006.
Mark
Mark Craig Western DieselPerformance 1-888-621-4006 2000 Crew Cab Dually, 6 speed, 4.10 Limited Slip, Lariat. Toys are Turbo Brake, Turbo Chip, Turbo Gauges A-Pillar Mount, Turbo Foam Air Filter.
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
