Old 03-06-2006, 04:11 PM   #1 (permalink)
Got my V codes today.
Ordered from the dealer last Friday. Code # 3C34-5310-ADA Picked them up today.
Same number that everyone else is ordering. Suprised at the weight on them for just a 2 leaf. I know that I have seen the ones in the truck, but seeing them out of the truck is another suprise as to the size. I guess I'll be even more suprised by the rears.
I ordered a set of U bolts and nuts. I heard they had to be replaced per Ford instructions because of torque to yeild. Is this right? Also, do I need to replace the eyebolts?
I'll be putting them on Thursday and Friday.
Now I am in the same boat as Bruce1954. I need to figure out what to put in the rear.
There is a spring company called Triangle Spring Works just accross the Delaware river in Philadelphia. They make springs and will make custom. I called them and the guy said that he can make a set to my specifications. I'm gonna go over and talk to him tomorrow. He says he can make something that will give me a nice ride and still carry the load, and at whatever height I want and even design the rate with airbags in mind.
So, Bruce, you got any suggestions on what rates and leaves, etc.? Looks like I'll have the cash for them by April first, and I'll either buy the B codes or have the custom made.
2005 EXCURSION!! XLT V10 Silver Purchased 10/8/05 19920 Miles.
Heated tow mirrors, Hood/window deflector,Ford rubber mats, Firestone bags/air source kit, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Curt front reciever, 6 disk Visteon stereo, 6 disk changer in console, X-3 AIC, door lights,OEM Fog mod, volt/tran temp gauges,skid plate.
housedad is offline
Old 03-08-2006, 06:19 PM   #2 (permalink)
bpcheramie's Avatar
Re: Got my V codes today.
what did you pay for your spings?
Brent
01 Excursion 4X4 - DIY Injectors, Garrett GT38R, DI Regulated Fuel Return, HX CrossOver, AFE stage II, Diamo 17 Karat 18x10.5 w/ 325x60x18, 4" straight pipe exhaust, DI 6 position chip, X and F Springs with F350 Rear Blocks and .....................
01 Excursion 4X4 - RIP 2/22/2008
All work has been done by Diesel Innovations!!!!! Thanks to MR POWERSRTOKE RACER for all the help.
bpcheramie is offline
Old 03-08-2006, 07:35 PM   #3 (permalink)
With tax it was 143.50 each. He got for me wholesale, but the shipping killed him as tthe warehouse just threw them in with an overnight order. Who says warehouse clerks don't have a sense of humor?
Update:
I went to Triangle springs today and had a long talk with their resident engineer. It seems that he is able to do everything that I want:
Ride height 1/2" heigher than the front with V codes. I like a forward rake.
Soft ride on first stage with bags until laden with tongue weight.
2nd stage strong as a 350.
poly bushings and teflon spacers.
I took all of the info that I had, weights of truck, Expected trailer weights and lengths, Expected cargo towing and not towing, yada yada yada.
He is also going to work some numbers on the front end.
He says he will be able to get all of his calculations done by Tuesday, so I will find out then.
Expected price about $250 each.
Has anybody heard from Bruce?
housedad is offline
Old 03-08-2006, 09:31 PM   #4 (permalink)
Still here just been to tied up to do anything extra during the day.
Like call airlift
Bruce
Bruce1954 is offline
Old 03-17-2006, 10:07 AM   #5 (permalink)
Housedad,
Any word on your custom springs yet? I'm curious to hear what the "ideal" springs are for your application. Also, I would like to know what data you supplied them, so I could see how it compares to my application.
Thanks,
Rob
2001 Excursion Limited 4X4, V10
Done so far:
Rear Hellwig (#7643),
Front Poly Frame Mount Sway Bar Bushings (Energy Suspension #4.5180G),
Gen II Landyot Radius Rods,
Rancho RS9000X's (RS99267 front, RS99266 rear),
Rancho steering stabilizer (RS5410),
Super Duty Front Bumpstops (F81Z-3020-DA)
Domelight & Foglamp overrides, Heated & Lighted TT Mirrors, Silverstars, Husky Floor & Cargo Liners, Husky molded mudflaps, V10 badges, OEM clear headlights & corners, latex tubing in door weatherstrips
U Code Front Springs (2C3Z-5310-GA),
F Code Rear Springs (6C3Z-5560-F) with added leaf from original spring pack (the 38" long leaf, 3rd from bottom, not including anti-wrap leaf)
Landyots Removed during spring change, may add Gen IV's in the future as an experiment
<span style="color: blue">2001 Excursion Pictures and Mods</span>
towrig is offline
Old 03-17-2006, 10:56 AM   #6 (permalink)
Mudraga's Avatar
I've been religiously reading all the spring swap threads for a while now, just soaking in the knowledge so to speak. One tidbit of information I haven't seen yet is:
How are the springs identified?
All this talk of V codes and B codes, etc. Are there markings on the springs somewhere that correspond with these "codes"?
2002[1/02] Excursion 4x4 Ltd. PSD,Unknown chip/program, K&N GenII FIPK Air Filter, straight pipe exhaust, Autometer Z Series pyrometer and boost gauges, Air Lift SuperDuty air bags with Load Controller II onboard air system, Sonnax Tricumulator, HX hose.
Mudraga is offline
Old 03-17-2006, 02:52 PM   #7 (permalink)
I just received the complete set of 4 (Vs &amp; Bs), $601.00 for the complete set, shipping was drop ship from Ford to a brother-inlaw commercial addy. $128.40/ea for the front / $161.79/ea for the rears.
$20.00 for the u-bolts.
The dealer I ran the order through noted shipping from him via his stock would have been no less than $120.00, but he has had springs dropped shipped from Ford to cusomters before and shipping costs to him were $20.00. So I figure if I get hit with $50.00 I'm still way ahead. Also, the drop shipping took only 2 days. He ordered the springs Tuesday and one set showed up yesterday and the other today. Worked out great.
I have the PNs for my order if anybody is interested for reference.
Chris H
'04 F150 Lariate - 5.4
'01 GT 'stang - 4.6
'00 PSD Exec - 7.3
'92 Bronco - 393 stroker
'69 F250 Ranger C/S 360fe
ChrisH is offline
Old 03-18-2006, 07:46 PM   #8 (permalink)
Please.
Stewey is offline
Old 03-18-2006, 11:11 PM   #9 (permalink)
V front spring is part number 2C3Z-5310-HA, uses F81Z-2705-ZA U-bolt
B rear spring is part number 3C3Z-5560-CB uses F81Z-5705-BB U-bolt.
Took pics of the labeling on the springs.
Side note I measured the arch on the B @11-5/8 / 28.7cms
Thanks,
Chris
Chris H
'01 GT 'stang - 4.6
'00 PSD Exec - 7.3
ChrisH is offline
Old 03-19-2006, 06:41 AM   #10 (permalink)
Thanks, Chris.
Stewey is offline
Old 03-21-2006, 01:24 PM   #11 (permalink)
Here is what worked out after I went to the shop 3 times and discussed the issue at length.
A custom spring will cost between $400 and $500 per spring. He did work up the rates and leaves to give me the best ride and still give a 6830 load.
This means that it would have a initial rate higher than the F350 DRW. This is caused by the 1000lbs higher curb load on the rear of the Excursion as opposed to the 350.
Suprisingly, (or not) What he calculated turned out to be Damn close to the Standard B code but with a higher arch and 360/680 rates. (The secondary rate varies some depending on where we are in the argument)
He figured that with the bags, the 360 rate would allow sufficient travel to give a good ride, and the second stage would provide sufficient load carrying if the bags were not used.
Now, here is the fun part: He still needed to go for a higher arch to meet hight requirements.
Well, we bantered back and forth some, and the conclusion as far as cost and complexity was that it is cheaper by far to modify an existing spring.
So, I decided to get a set of 2004 B codes that he has from a take off, (he has several laying around) have them re-arch them 1.75" to 2" higher. With the bags, it should be good.
I'll add the Firestone 2" spacers to the airbags. (already ordered)
He can replace the second leaf to give a higher first stage if I want. I am still thinking about this. It adds to the per spring cost, and I want to keep the cost down I know - penny wise and pound foolish!!!
This will give me a little front rake. All is good.
I'll be picking the set up at the first half of April, when I have enough cash saved.
Wish me luck!!! [img]/ubbthreads/images/graemlins/smile.gif[/img]
housedad is offline
Old 03-21-2006, 07:22 PM   #12 (permalink)
HD...so what's the final cost? Inquiring minds need to know.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Gun Control means using both hands.
Stewey is offline
Old 03-22-2006, 10:32 AM   #13 (permalink)
Way to much$$ for those springs [img]/ubbthreads/images/graemlins/eek.gif[/img] Betts springs in CA. can make a pair for $500.00. You could also take the SD rears and add 1 or 2 of your stock leafs to get the weight rating up.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 03-23-2006, 06:14 PM   #14 (permalink)
Why is the part number for Housedad's V springs different from the part # for ChrisH's V springs?
Stewey is offline
» Sponsor Links
