Old 06-07-2004, 01:24 PM   #1 (permalink)
Got VIN number, want meaning.
I've played around with the search facilities here. They don't seem to work well at all. I also searched on the net a bit, but that was only partially frutful.
My new VIN is 1FMSU45Px4Exxxxxx. Obviously, I'm not filling in the 'x's for you. So far, I think:
<ul type="square">[*]1FM = Ford USA[*]S = 9000 to 10000 lb GVWR[*]U45 = Excursion, 4x4, EB? (so far, I havn't found U45 listed, but that's what I have[*]P = Powerstroke 6.0? (also not listed that I could find)[*]4 = 2004[*]E = Kentucky Truck Plant.[/list]
If someone could confirm the missing bits, it looks like I could be picking this up next week. Heh. I don't know the build dates yet ... or what's on the door jamb. I assume that it's still in transit.
I have to say that I'm getting more excited now.
2004 Excursion EB 6.0 Estate Green. As yet, unmodified. Delivered 2004-07-14
Zaphod is offline
Old 06-07-2004, 02:19 PM   #2 (permalink)
Re: Got VIN number, want meaning.
U45 is an EB 4x4 X.
The 6.0 is engine 99P, so the P means a 6.0
jschira is offline
Old 06-07-2004, 02:52 PM   #3 (permalink)
My Photos: (21)
The first three vehicle identification number (VIN) positions are the world manufacturer code.
1FD — Ford Motor Company, USA, incomplete vehicle
1FM — Ford Motor Company, USA, multi-purpose vehicle
1FT — Ford Motor Company, USA, truck, completed vehicle
2FM — Ford Motor Company, Canada, multi-purpose vehicle
3FD — Ford Motor Company, Mexico, incomplete vehicle
The fourth VIN position is the vehicle brake type and GVWR code (all vehicles use hydraulic brakes).
N — 8,501-9,000 pounds GVWR with driver and front passenger air bags
S — 9,001-10,000 pounds GVWR with driver and front passenger air bags
W — 10,001-14,000 pounds GVWR with driver and front passenger air bags
X — 14,001-16,000 pounds GVWR with driver and front passenger air bags
A — 16,001-19,500 pounds GVWR with driver and front passenger air bags
H — 8,501-9,000 pounds GVWR, without air bags (Mexico)
J — 9,000-10,000 pounds GVWR, without air bags (Mexico)
K — 10,001-14,000 pounds GVWR, without air bags (Mexico)
L — 14,001-16,000 pounds GVWR, without air bags (Mexico)
M — 16,001-19,500 pounds GVWR, without air bags (Mexico)
Positions 5 through 7 indicate vehicle line, series and body type.
F20 — F-250, Regular Cab, 4x2, single rear wheels
X20 — F-250, SuperCab, 4x2, single rear wheels
W20 — F-250, Crew Cab, 4x2, single rear wheels
F21 — F-250, Regular Cab, 4x4, single rear wheels
X21 — F-250, SuperCab, 4x4, single rear wheels
W21 — F-250, Crew Cab, 4x4, single rear wheels
F30 — F-350, Regular Cab, 4x2, single rear wheels
X30 — F-350, SuperCab, 4x2, single rear wheels
W30 — F-350, Crew Cab, 4x2, single rear wheels
F31 — F-350, Regular Cab, 4x4, single rear wheels
X31 — F-350, SuperCab, 4x4, single rear wheels
W31 — F-350, Crew Cab, 4x4, single rear wheels
F32 — F-350, Regular Cab, 4x2, dual rear wheels
X32 — F-350, SuperCab, 4x2, dual rear wheels
W32 — F-350, Crew Cab, 4x2, dual rear wheels
F33 — F-350, Regular Cab, 4x4, dual rear wheels
X33 — F-350, SuperCab, 4x4, dual rear wheels
W33 — F-350, Crew Cab, 4x4, dual rear wheels
F34 — F-350, Regular Cab (Chassis Cab), 4x2, single rear wheels
X34 — F-350, SuperCab (Chassis Cab), 4x2, single rear wheels
W34 — F-350, Crew Cab (Chassis Cab), 4x2, single rear wheels
F35 — F-350, Regular Cab (Chassis Cab), 4x4, single rear wheels
X35 — F-350, SuperCab (Chassis Cab), 4x4, single rear wheels
W35 — F-350, Crew Cab (Chassis Cab), 4x4, single rear wheels
F36 — F-350, Regular Cab (Chassis Cab), 4x2, dual rear wheels
X36 — F-350, SuperCab (Chassis Cab), 4x2, dual rear wheels
W36 — F-350, Crew Cab (Chassis Cab), 4x2, dual rear wheels
F37 — F-350, Regular Cab (Chassis Cab), 4x4, dual rear wheels
X37 — F-350, SuperCab (Chassis Cab), 4x4, dual rear wheels
W37 — F-350, Crew Cab (Chassis Cab), 4x4, dual rear wheels
F46 — F-450, Regular Cab (Chassis Cab), 4x2
W46 — F-450, Crew Cab (Chassis Cab), 4x2
W42 — F-450, Crew Cab (with box), 4x2, dual rear wheels
W43 — F-450, Crew Cab (with box), 4x4, dual rear wheels
F47 — F-450, Regular Cab (Chassis Cab), 4x4
W47 — F-450, Crew Cab (Chassis Cab), 4x4
F56 — F-550, Regular Cab (Chassis Cab), 4x2
W56 — F-550, Crew Cab (Chassis Cab), 4x2
F57 — F-550, Regular Cab (Chassis Cab), 4x4
X46 — F-450, SuperCab (Chassis Cab), 4x2
X47 — F-450, SuperCab (Chassis Cab), 4x4
X56 — F-550, SuperCab (Chassis Cab), 4x2
X57 — F-550, SuperCab (Chassis Cab), 4x4
W57 — F-550, Crew Cab, (Chassis Cab), 4x4
U40 — Excursion, 4x2, XLT
U41 — Excursion, four-door, 4x4, XLT
U42 — Excursion, four-door, 4x2, Limited
U43 — Excursion, four-door, 4x4, Limited
The eighth VIN position is the engine displacement and number of cylinders.
L — 5.4L, Modular, SOHC, EFI, V8, Gas
S — 6.8L, SOHC, EFI, V10, Gas
F — 7.3L, OHV, DI Turbo, V8, Diesel
Z — 6.8L, gaseous fuel prep (F-Series)
D — 6.8L, propane only (F-Series)
B — 5.4L, propane only (F-Series)
The ninth VIN position is a government assigned, computer-generated check digit.
The tenth VIN position is the model year code.
· 2 — 2002
The eleventh VIN position is the assembly plant code.
S — Allen Park (Allen Park, Michigan)
E — Kentucky Truck (Jefferson County, Kentucky)
M — Cuautitlan (Cuautitlan, Mexico)
The last six VIN positions are an alphanumeric code for the vehicle build sequence. This is also the vehicle serial and warranty number.
· A0000-E99999 — Ford Division
hope this helps.
JIM
His: 1997 F350 PSD, CC, 4X4, 4.10's, 35/12.5/16.5's BFG's
Hers: 1997 F250 PSD, X-Cab, 4x4, 4.10's, 315's
All My Photos
Toys/Blown Head Gasket
Drag Videos
motor/turbo/fuelsystem pics
Traction Bars
Father & Son Time
THE_ALASKAN is offline
Old 06-07-2004, 07:28 PM   #4 (permalink)
You need to update that with the U45 body code and the P engine code.
Zaphod is offline
» Sponsor Links
»Garage Storage and Cabinets
