Old 02-20-2003, 02:46 PM   #1 (permalink)
"Harpoon" tank vent mod??
Has anyone done this modification to an Excursion fuel tank? If so, what were the results?
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 02-20-2003, 02:52 PM   #2 (permalink)
My Photos: (11)
Re: "Harpoon" tank vent mod??
I did not look at it while I had the tank out, but have never really had a problem with getting the tank filled, I can only get maybe another gallon in after the pump clicks off. I'm not sure if we have as a bad a problem as the SD's
2002 PSD Excursion 2WD, VDO guages, PPIII, pre-pump and tank mods, ZooDad, 4" exhaustw/ Magnaflow muffler and downpipe, Bilsteins, Hellwig bar, Air Lift rear bags, monochrome SD grille and bumpers, 20" Weld Velociti 8's
swhitney is offline
Old 02-20-2003, 04:37 PM   #3 (permalink)
Mine will take 4 more gallons if I take the time. I usually don't.
AJ'sDad is offline
Old 02-20-2003, 07:06 PM   #4 (permalink)
CHPMustang's Avatar
My assumption is that the X has it already,sorta like the Pickups have the rear sway bar and we have the big tank vent [img]/ubbthreads/images/graemlins/tongue.gif[/img]
There's something different about the X tank for I can go to any Card lock which fills at the pace of a gallon every 3 seconds and I don't get no burp when it's filled like we did with the F250.
That's my theory to it [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 02-21-2003, 10:13 AM   #5 (permalink)
I've never had a burp/overflow problem with my truck using the big truck pumps either. I'm just looking for a faster way to get the last 4 gallons of fuel in.
AJ'sDad is offline
Old 02-21-2003, 10:55 AM   #6 (permalink)
CHPMustang's Avatar
Has anyone's(EXCURSION) had a totally empty tank and then filled it to see how many gallons the tank plus the short neck holds?
BILL
Old 02-21-2003, 11:10 AM   #7 (permalink)
I've pumped 44 gallons into mine, when it wasn't empty.
AJ'sDad is offline
Old 02-21-2003, 12:39 PM   #8 (permalink)
My '99 SuperDuty Supercab had a 29 gallon tank. I put 31 gallons in it one time, and it wasn't empty either.
jschira is offline
Old 02-21-2003, 07:18 PM   #9 (permalink)
The last time I filled the tank on my 03X, my 'miles to go' display read 0 for almost 2 miles before I got to the truck stop. I put 45.642 gals in, which filled it all the way to the top of the fill pipe. I wasn't really trying to see how much fuel I could put in, but I don't think I would have gone much farther before I had to start walking!
Dave
03 Exursion 4x4 7.3L PSD Limited; Mineral Grey Metallic Clearcoat; Rear DVD Entertainment Center; Ford Gold Remote Start; BD X-Monitor; Husky Mud Flaps (front & rear); DiabloSport Preditor; Hellwig rear anti-sway bar; Ford AIS Severe Duty Filter
Artful_Dodger is offline
Old 02-21-2003, 08:13 PM   #10 (permalink)
CHPMustang's Avatar
Just as a note to the new PSD owners,when letting your fuel level to drop 1/4 tank or less,it allows for more air to enter the fuel line going to the injectors which can cause enhanced noise and possible injector failure. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Then again that's what warranty is for [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
Just wouldn't want to be without my truck while it sits in the service drive waiting to get worked on [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
BILL
Old 03-12-2003, 09:32 PM   #11 (permalink)
I have put 42 gallons in a 38 gallon tank was running on fumes trying to find someone who sold diesel!!!
2003 F-250 XLT Super Duty 7.3 Liter Ext. cab automatic, 2X4, 3:73, VDH5, U.S.M.C. Semper Fi!! Gulf War Vet, NRA Benefactor Life Member
P_S_D is offline
Old 03-12-2003, 09:41 PM   #12 (permalink)
BILL
ran mine down to "0" this weekend .couldn't find diesel.
must've been on fumes but I pumped 46.75 gallons and could see the fuel around 4-5 inches beyond the metal flap.
Saw your follow up post that says running under a 1/4 tank can let air in and damage the injectors.This is the 2nd or 3rd time I've been stuck like this.Now you've got me wondering if this might not be why I feel I've lost a bit of power.The engine also seems to knock a little more under acceleratrion than it used to .
'02 PSD LTD Ultimate X Rancho17000's/Ucodes/SkyjackerDual steering stabilizer/Addco Swaybar/REVO'S/Stuhl billet grille/17"Ford Air Horns Behind the grille!
ford_x_3 is offline
Old 03-13-2003, 10:57 AM   #13 (permalink)
When mine used to cackle, it was definitely worse below 1/4 of a tank.
AJ'sDad is offline
» Sponsor Links
»Garage Storage and Cabinets
