Old 06-30-2005, 09:59 AM   #1 (permalink)
My Photos: (16)
Headlights no low beam
No low beam or daylight running lights. High beam works fine as do the parking lights and turn signals.
I have checked the fuses in the cab as well as the fuses under the hood. Have removed the headlight switch assembly no burnt wires but its a sealed unit with a board inside. Could it be the switch is faulty. Anyone else had this problem?
DUNC
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
Old 06-30-2005, 10:16 AM   #2 (permalink)
rock_doctor's Avatar
Re: Headlights no low beam
Sounds like the high beam switch is bad. When you shift to high beams, do the lights go off?
I am not familiar with fords but for GM products, the high beam switch is mounted lower on the column and connected to the lever with a push rod. Somebody else who is familiar can tell you how to replace the switch. It should not be too difficult.
good luck,
mark
2005 Excursion w/ 6.0L PSD
rock_doctor is offline
Old 06-30-2005, 10:22 AM   #3 (permalink)
My Photos: (16)
No low beam.
If I select high beam I can turn them on and off. That part is working fine.
DUNC
DUNC is offline
Old 06-30-2005, 09:06 PM   #4 (permalink)
Low beam is what I meant. Generally, the way it is wired is the light switch on the dash feeds power to the high/low beam switch, which in turn selects where to send the power. I would try to locate the switch, switch it to low and see if you have power leaving the switch when on low beam. If so then the wiring between the switch and the headlights are bad. If there is no power coming out of switch on low beam then switch is bad. I believe this is a diagnosis you can make yourself. You can do this with a test light or invest in a $20 voltmeter. I have one in each car just for the purpose of diagnosing breakdowns.
good luck,
mark
Old 06-30-2005, 10:06 PM   #5 (permalink)
Location: Lumberton, Republic of Texas , Hardin County . and US of A
Dunc I think there are some relays under the hood in one of the fuse boxes. One of them could have gone bad. May be one inside, not sure. If you have no burnt wires and the bulbs are good then that is the likely culprit. Pull up on the windshield wipper stalk and see if both high and low beams come on. If bulbs are good and they do then you have a switch, relay, or circuit9it breaker problem.
[img]/ubbthreads/images/graemlins/crazy.gif[/img] - Ed
Even though we vote for the lesser of two evils we still end up with evil!!
_________________________________________________
I have a full scale atlas of the USA. One mile equals a mile...It is really hard to fold!!
<font color="red">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~</font>
SMILES and the best to all**Ed-<font color="red">RETIRED</font>**OINKING-BILGE-RAT
<font color="red">FREEDOM IS NOT FREE ! ! !</font>
2005 LTD. X PSD 2WD FIBERGLASS RUNNINGBOARDS; SUNVISOR: REAR DEFLECTOR
<font color="00FF00">BENEFACTOR**<font color="red">NRA</font>**<font color="red">LIFER</font>**<font color="red">TX.ST.RIFLE ASSOC</font>**<font color="red">GOA</font>**<font color="00FF00">MEMBER</font>**<font color="00FF00">NRA/ILA</font>**<font color="red"> I VOTE ! DO YOU ? </font>**QUACK*QUACK ! ! !
<font color="00FF00">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~</font>
H ED S is offline
Old 07-01-2005, 12:52 PM   #6 (permalink)
My Photos: (16)
Switch tested and power is leaving on lo beam. You mention a relay or possible junction box inside the cab. Any ideas where?
DUNC
EDIT:I think there is one behind the glove box??
If so where and how to test??
DUNC is offline
Old 07-02-2005, 04:04 PM   #7 (permalink)
There are no relays in the stock head light circuit.
What switches have you tested?
My moneys is on a bad multifunction switch on the steering column or a loose wire at the switch. Try tilting the steering column up and down and see if the lights work.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 07-03-2005, 07:35 AM   #8 (permalink)
My Photos: (16)
I have tested the switch on the dash and the multifunction switch
Both tested as working. I have Dylight running lights and member
klhansen has provided me with the wiring diagrams.
It's not an easy one to follow.
Still " plugging " away at this [img]/ubbthreads/images/graemlins/grin.gif[/img]
DUNC
DUNC is offline
Old 07-03-2005, 11:53 AM   #9 (permalink)
Oops I messed up and forgot to see you have day time running lights so there are 2 relays in a relay block under the dash on the right side toward's the center of the dash according to the wiring book I have. We don't see too many vehicles down here with the DRL setup so I am really not sure where the relay block is mounted. I would steal a couple of the relays out of one of the other relay boxes on the vehicle and swap them out and see if this solves your head light issue. I would have to agree that the wiring diagram is slightly difficult to follow. The DRL system works by shutting relay 2 is off but it is completing the circuit to the DRLs when the head light switch is off and this second relay supply's power to relay 1 which makes the DRLs come on. With the head lights on relay 2 is powered up and relay 1 is just there to complete the circuit to the head lights in the normal fashion.
FMT
Excursion Pics
Old 07-03-2005, 03:23 PM   #10 (permalink)
DUNC
If you have DRL it's very easy to disable them and see if the system works normally without them.
Behind the headlight (actually behind the radiator core support), on the drivers's side is located the load resistor for the DRL. Just unplug the connector that is plugged into this big resistor and this will disable DRL. this should put your headlights in normal mode of operation.
If you want to remove the relay system, it's behind the glove box, but you'll need the jumper connector to put in the plug if you unplug the relay bank. Hopefully you still have that. Otherwise if you unplug the relay pack, nothing will work.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 07-05-2005, 07:16 AM   #11 (permalink)
My Photos: (16)
Problem solved.
I would like to thank all of you for your help.
So the problem was an intermittant relay in the DRL'S and a connector at the DRL resister that when plugged in only one contact was actualy fitting over the pin. The drivers and passenger side headlamp connector low beam wire bad.
Passenger side bulb that tested fine everytime I removed it only to find that when installed no low beam.The last time I removed the bulb
It was still connected to the harness no low beam??? I tapped it a couple of times and it came on. Bought new bulb.
I could go into great detail about how the intermittant relay and bulb caused me nothing but trouble,retesting time and time again.
Isn't electrical fun [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Thanks again
DUNC
DUNC is offline
