Headstuds 04 Excursion - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-11-2009, 08:52 AM   #1 (permalink)
Has anyone replaced the headbolts with headstuds without having to pull the body off. (04 excursion 6 liter)
mettlerj is offline
Old 11-14-2009, 06:46 PM   #2 (permalink)
dvldog458's Avatar
My Photos: (54)
Send a message via AIM to dvldog458
i had it done a few months ago at the dealer. They pulled the front clip off and pulled the engine out with the trans. They replaced my egr system and installed new head gaskets w/ ARP head studs.
2004 Excursion Limited 4x4 6.0L
BDS 8" lift, 2.5" shackle kit w/ 37" Nitto Mud Grapplers, 20x10 Jesse James wheels, SCT tuner (Elite Diesel) A-1 H-11 Head studs, Dieselsite coolant filter
dvldog458 is offline
Old 11-15-2009, 10:43 PM   #3 (permalink)
Just finished doing injectors on passenger side. Space was so tight with evap coil could not use sockets had to use open end wrench with adapters to get to back bolts. Pulled wheel well to get in there. Good luck removing a head let alone torquing it back down. If you remove evap coil that side of the truck would be easy to work on.
Swan59 is offline
