Old 04-10-2002, 03:35 PM   #1 (permalink)
Hellwig Installation
I installed my Hellwig sway bar last week. The installation went fine, but I have one question to any of you who have had one installed or installed one yourself. What did you do with the emergency brake line hanger? This had to be removed in order to install the sway bar link. The instructions are not clear on what to do. Did you rehang it somewhere?
Clif Smith - Austin, Texas
1997 F-350 PSD, 2WD, Crew Cab. Bone Stock.
Previously owned PSDs:
-2000 Excursion Limited 4x4. Modified Out.
-1999 F-250 Superduty Extended Cab - Stock
clifsmith is offline
Old 04-10-2002, 09:56 PM   #2 (permalink)
Re: Hellwig Installation
Good question. I remember remounting I think one hole over. Wait a second and I will go out and look.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 04-10-2002, 10:10 PM   #3 (permalink)
Well so much for my memory. I reinstalled the hanger on the outside of the frame utilizing the same bolt that supports the bar. I just slipped the hoop around the head of the bolt.
Hope this helps.
John
JADFPE is offline
Old 04-11-2002, 08:07 AM   #4 (permalink)
There are 2 holes to mount the link to. The closest hole to the link is the hole that the brake line bracket bolt goes through. This hole is exactly the same diameter as the sway bar link bolt. The other hole (about 1/4" back and 3/4" higher) is slightly larger. I used these slightly higher and larger holes. I put the brake line braket back where it was but I had to reverse the bolt and grind the head some. This seems to work. I just did not like the idea of attaching that brake line bracket to link bolt itself.
Old 04-11-2002, 10:39 PM   #5 (permalink)
What size/length bolt connects the link to the frame? I seem to be missing that bolt on the driver's side. [img]/ubbthreads/images/icons/frown.gif[/img]
ptemplin is offline
Old 04-12-2002, 10:31 PM   #6 (permalink)
Any comments as too the liking or disliking of your anti sway-bar addition? Worth the $$? Any idea on cost?
aquaholic is offline
Old 04-12-2002, 11:23 PM   #7 (permalink)
The rear didn't seem to make a major difference, but don't put a lot of validity into my comment until I reconnect it tomorrow. It lost a bolt for unknown reason, and is essentially disconnected.
The front was absolutely amazing. I had my Rancho shocks dialed up to 5, and was wishing for 6 or 7 and afraid that I would need dual shocks or something. After I put on the new front bar, I ended up lowering the front shocks to 2 I believe. I hit an admittedly severe manhole cover dip, and could feel the bump on both sides for the first time after I installed the front bar.
ptemplin is offline
Old 04-16-2002, 01:51 AM   #8 (permalink)
I may be a little late with my reply, but here are pictures of my install:
http://fordexcursions.superford.org/...;s18=&s19=
You can see how I did the e-brake cable on this pic:
http://fordexcursions.superford.org/...c.php?pID=1917
-Eric
'67 Galaxie Pics | '00 Excursion Pics
erlong is offline
» Sponsor Links
»Garage Storage and Cabinets
