Just got rear hellwig sway bars installed today. Have a 2001 4x4 PSD with bilsteins.
My overall goal for my Ex is to improve ride, handling, and wandering.
Bilstein's were the 1st mod and the biggest improvement in all of the above. 60 PSI helped alot as well.
Then got the Hellwigs installed at an alignment shop. The instructions were truely crap but they eventually figured it out. Took 1 hr and charged 1hr labor. They did a nice job with fitting and greasing the bushings.
In straight line, the hellwigs don't do much to improve the ride or wandering. It stiffens the rear and makes the ride significantly stiffer/harsher. It's most noticeable on medium speeds 30-40 mph on bumpy roads, it's not so noticeable on the freeway.
But the changing lanes/any cornering, the improvements are great! No longer feels like piloting a barge, much more secure/flat/and planted.
Definately worth around $210 installed but some may find the increased stiffness in ride objectionable.
2001 Excursion PSD
Suspension: Bilsteins, Hellwig
Engine: Prepump/Fuel tank mod. Regulated fuel mod
Other: Sound deadener
Thank you! I looked at JC whitney and only found the FRONT bar...I guess I better look again...lot better deal then $ wheel parts...
Thanks again
Tom [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
CTFD
Contact Info.. tom@reynolds-excavation.com
512-762-1485
LATE 1999 F350 CC Dually 2WD,4" stainless Magnaflow.Highly Modified GT38 Turbo
DP-Tuner 4 Pos. chip, PS2000,4" intake with fleetguard filter ,Suncoast Tranny With Triple disc T/C, Lunar Guages
12 Speaker 770 watt Fosgate,Sony and Infinity system with (((XM))), Stull Billet,BFG's and acetoned badges.ART rotors, More to come. 8100lbs.
1/4 mile 14.80 @ 94.24 MPH
2000 Limited 4X4 Excursion Toreador red and tan,(((XM)))Rancho RSX's, Hellwig anti sway,V codes on front, skyjacker dual stabilizer, Edge Evolution AFE with PG7, Eddins House of Diesel 4" Exhaust with Polished 5" tip, Suncoast tranny with triple lock, 15.1" DVD monitor,now rolling Akuza Bounce 20's w/ Toyo 305/55/20 AT's
