Old 02-07-2004, 02:14 AM   #1 (permalink)
BDS
Hellwig Sway Bar or Add-A -Leaf?
I'm going to do the X spring upgrade soon and will be installing an add-a-leaf in the rear (Ranchos) Anyway, with the "little" increased spring rate from adding the add-a-leaf do you think I would have to add the Hellwig sway bar aswell? I'm trying to kill two birds with one stone here, or is it impossible? I'm thinking if I'm going to have to lift the rear with an X spring install I figured I would lift it with a leaf and hopefully stiffin it up a little [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Or should I just lift the rear the cheaper way and buy a hellwig?
Brent.
96' F350 XLT C/C PSD 4X4 LWB-Green...His, SOLD IT, Stupid Move, Found Another!
97' F350 XLT C/C PSD(for now) 4X4 LWB-White...His
01' Excursion PSD 4X4 Limited...Hers
Trucks
Sled Pull
BDS is offline
Old 02-07-2004, 06:35 AM   #2 (permalink)
Re: Hellwig Sway Bar or Add-A -Leaf?
A Jack of all trades is a master of none [img]/ubbthreads/images/graemlins/crazy.gif[/img]
So sometimes killing two birds with one stone doesn't do either bird any good [img]/ubbthreads/images/graemlins/phoney.gif[/img]
The rear sway bar will do WONDERS for your Ex if u don't have a rear bar now... you'll wonder HOW in the world you ever got by without it..
the springs may HELP the sway, but at the expense of a little ride quality...
the rear bar @ JC Whitney is like $130 delivered ????
Well worth it... just search for and read the before and afters on the hellwig installs here...
05 4x4 6.0L EB Ex.... only 2 mods..8.9 @ 74 1/8th
gone but not forgotten 03 4x4 6.0L Lim Ult Ex...
even goner 02 4x2 7.3L Lim Ex buyback
jdadamsjr is offline
Old 02-07-2004, 07:20 AM   #3 (permalink)
BDS
Thanks, I do have the OEM one but I know it's not up to the capabilities of the hellwig. Now I just need to decide on how to lift the rear.
Thanks,
Brent.
Trucks
Sled Pull
BDS is offline
Old 02-07-2004, 09:14 AM   #4 (permalink)
An OEM sway bar on an '01 X? [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
'02 Excursion Limited 4X4 PSD- Helwig Rear Sway Bar, Bridgestone Dueler A/T Revos, Rancho 9000s, V-Codes, '03 Stops, F-350 Rear Blocks, Drilled and Slotted Rotors W/ Ceramic Pads, 4X2 Hatch Struts, Rear Air Deflector, AFE Intake,203* T-Stat and Billet Housing, HD-ELC (GO RED), Ford AIC, Jotto Desk , Sylvania Silverstars, '03 Badges, Wipers - 24" Front 17" Rear, Auxiliary Back-Up Lights, Reverse Sensor Alarm Override Switch
Dentman is offline
Old 02-07-2004, 11:11 AM   #5 (permalink)
FamilyRide's Avatar
If you're doing X Codes, I think you can use F350 rear blocks and get it level without changing or adding springs.
If you have the OEM rear bar, the improvment may be there, but it may not be "economicly feasible". (bang for the buck may be more like a pop for the buck [img]/ubbthreads/images/graemlins/laugh.gif[/img])
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 02-07-2004, 12:30 PM   #6 (permalink)
If you do have an OE bar (on a 2001 [img]/ubbthreads/images/graemlins/confused.gif[/img]) then you might but in a 30MM bar for under $50
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 02-09-2004, 12:03 AM   #7 (permalink)
BDS
Well I'll Be darned [img]/ubbthreads/images/graemlins/blush.gif[/img]! I was mistaken, I don't have a rear sway bar. I was under the assumption I did without even looking. I guess I'll be installing the Hellwig for sure now.
As for the lift, I was concidering the add-a-leaf to stiffin her up a bit back there. Call it stupid, but I just don't like the soft ride. Then on the same token I don't want it to ride like my 96' 350 by any means [img]/ubbthreads/images/graemlins/vomit.gif[/img] That beast with it's back-ass-wards shackle design up front will knock your teeth loose!
Thanks,
Brent.
Trucks
Sled Pull
BDS is offline
Old 02-09-2004, 12:26 AM   #8 (permalink)
MotionMan's Avatar
X codes will be a little short in the back, you will need a 4" block. If you want to stiffen, raise, and not install the sway bar you should go with air bags, they can be stiff, 0-100psi stiff, will raise the truck as much or more than 2" and strenghten the back side to side motion and body roll which is what the sway bar does. You can kill three birds with one stone..and you get great leveling when you have a lot of tounge weight.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 02-09-2004, 04:26 PM   #9 (permalink)
My Photos: (13)
The Hellwig Sway Bar is an absolute must have. You'll notice a BIG difference in handling and I had the OEM bar before.
2003 Eddie Bauer Excursion (born 8 Apr 03), 6.0L Power Stroke Turbo Diesel w/8 C95 Fuel Injectors, Oxford White & Arizona Beige, 4x4, 5-spd Torqshift Transmission, 3.73 Rear, Two-tone Tan Leather Interior, Heated Seats, 6CD, Bull Rings, Adjustable pedals, Hellwig Sway Bar, Rancho 9000 Shocks, PSD Badges, Tekonsha Prodigy Brake Controller. McKenzie Starwood 29ft travel trailer.
[b]
My Excursion Pics (Updated 30 Dec 03)
<font color="red">CWO3, USN (ret), 24 years</font>
<font color="00FF00"></font>
MelloMike is offline
Old 02-10-2004, 03:27 AM   #10 (permalink)
BDS
I deffinately will go with the Hellwig sway bar! I'm still guessing on the rear lifting possabilities. I'll most likely do the block style lift and the sway bar and see if it's OK.
Thanks,
Brent.
Trucks
Sled Pull
BDS is offline
» Sponsor Links
»Garage Storage and Cabinets
