Hellwig Swaybar = Joke - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 05-01-2007, 11:52 PM   #16 (permalink)
Re: Hellwig Swaybar = Joke
Once the bar is on you will be happy. Almost makes it a sports car...............almost.
-2000 7.3L Excursion Limited. 2WD. White with tan. Hellwig rear anti-sway bar. Bilstein shocks. Rear air bags. 185,000 miles.
2000 VW New Beetle TDI
2005 VW Passat TDI...totalled
2006 VW Jetta TDI
DR.billZ is offline
Old 05-02-2007, 09:29 AM   #17 (permalink)
221
Is there just one sway bar in the rear or is there another one up front as well.
2004 White Ford Excursion Eddie Bauer 6.0 stock for now.
221 is offline
Old 05-02-2007, 09:39 AM   #18 (permalink)
The Same....I ended up with a ""pile"" of extra parts...
I probably have still got them somewhere, in a jar, or box...
The sway bar works very well, and would recommend to it anybody that doesn't have one on their Excursion
XS_SUV
Graupp is offline
Old 05-02-2007, 11:36 AM   #19 (permalink)
FamilyRide's Avatar
They all have one in the front, but not on the rear. It's rare to see someone replace the front as it's pretty stout as it is. If it doesn't have one in the rear, adding one is a huge improvement. If it does have one, upgrading to the larger 30mm Ford bar (comes on SD's) is cheap and easy thus worth it to do.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 05-02-2007, 02:45 PM   #20 (permalink)
Dunbar's Avatar
My 2003 X does not have a rear sway bar. Can I look at the shock mount to see if it needs to be replaced with a later one? What will I look for?
Can I order the hardware for an 04 X rear sway bar and get a larger 30mm Ford bar from the SD? If you, or anyone else, can confirm what I need to get I will order from the dealer after comparing prices online (minus shipping).
If it is easier to just get the Hellwig kit I am open to that but a couple of folks here are promoting the Ford OE parts.
Thanks,
David
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, Tymar DIY, Vcode & modified Fcode, Helwig, Inappropriately valved Bilsteins, Isspro 3 gauge w/ windshield mount, DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler,
BTS Transmission, DI Up pipes
Tomball Texas
Dunbar is offline
Old 05-02-2007, 04:27 PM   #21 (permalink)
David
You may not need a new mount on an 03 if it looks like the left you do not need a new one.
Take a look at Pict of 02 plate mod
You can see how the top of the plate was cut off.
I do not have a pict of the 05 but it is just like the left side of any X.
I think they relocated the E-Brake loop wire to the back side of the upper bolt of the shock mount.
If you what to go with the OE;
Order all the say bar parts for an 04 or 05X EXCEPT the bar
Order a 30MM bar for a SRW 250/350 with CAMPER Package
The parts book says 30MM because there is an 28MM also but I have never seen one.
Just as a reference the down link bars for an X are 10" for the 250 they are 14"; The ones you see on my 02 were made at 8" from the 14" ones prior to Ford comming out with them for the X.
There was a parts list here a while back.
Bruce
Bruce1954 is offline
Old 05-03-2007, 04:32 PM   #22 (permalink)
Dunbar's Avatar
I have tried several searches and get buried in stuff that has nothing to do with the rear sway bar. Either searching on this forum is different from all the others I am on or it is picking up on 'sway bar' in everyones signature.
Regardless, does anyone have a link to the part numbers for retrofitting a Ford rear sway bar onto a X?
I am going to go ahead and order a rear sway bar asap along with bilsteins. Then I will look into upgrading springs if needed.
Thanks Bruce & everyone else.
David
David Dunbar
Tomball Texas
Dunbar is offline
Old 05-03-2007, 06:56 PM   #23 (permalink)
Searching on this forum = Joke [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2003 E350 7.3L Extended Cargo - No Windows - Dipricol Optix: Pyro, Trans, boost - Walker BTM - Bellowed Up-Pipes - DP Tuner No Start, Stock, 60T, 80E, 120 Tailgaters special - Spectra Premium Fuel Tank Hutched & Harpooned (Ford Tank delaminated), Dual CAT Pre-pump Filter Setup
2003 GMC Sierra 2500 6.6L LB7 - Cognito UCA's, Bilsteins, Powdercoated H2's on 315 BFG AT's, PPE Standard
1993 Ford F250 7.3L "Black Beauty" 278K miles & is used to take the dogs out to play. Mods: 8,000lbs of Dog Hair.
SOLD: 2003 Excursion Limited 7.3L Mineral Gray 4x4
SOLD 2003 F250 SC LB 4x4 Silver w/ the 6.0L
HEAVYHITTER is offline
Old 05-03-2007, 08:14 PM   #24 (permalink)
Try searching with the "Subject only" box checked
Ferraris do not break down, They just sometimes stop to be admired [img]/ubbthreads/images/graemlins/grin.gif[/img]
1970 Brabham BT29 Formula B Race Car Blue/black
1999 Ferrari 355 F1 Berlinetta Red/Tan
2000 Excursion Limited 7.3 2X4 White/Grey
2002 Excursion Limited Ultra 7.3 2X4 White/Tan
2002 Mercedes CLK 320 Blue/Grey (wife's car)
Ferraridriver is offline
Old 05-03-2007, 08:54 PM   #25 (permalink)
I agree it is not easy it took be a good 10 minutes to find my own post from
MAY of 02 so this post will be gone soon in the searches
THE LINK BAR PART NUMBER IS FOR A 250/350 DO NOT ORDER IT FOR AN X!
Order the link bar for an 05 X an you will be fine.
link to the original 300MM bar in an X! 30mm bar in an 02 X
Does any one have the number for the drop link for the X????????????
Here is the list of parts I used in may of 02
The Parts I Bought Were.
1) F81Z-5A772-AA Sway Bar 30mm List $55.35
2)<font color="red"> F81Z-5K484-DA Link assembly that is 14" long for the X I shortened it to 8" long. List $20.13 Each NOT FOR AN X </font>
2) E5TZ-5486-B Listed as Ret. RR These were the U shaped mount covers for the sway bar mounting rubbers. $14.62 Each
2) E5TZ-5B498-KK Bracket, This is the flat on one side and curved on the other to fit the diff housing bracket. $13.80 Each
2) N803758-S56 U Bolt that goes around the diff housing to hold the above on. List $4.32 Each
Also these are 5 year old prices but they are list
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Old 05-03-2007, 09:15 PM   #26 (permalink)
Dunbar's Avatar
Bruce, you rock!
David
David Dunbar
Tomball Texas
Dunbar is offline
Old 05-04-2007, 12:02 PM   #27 (permalink)
Dunbar's Avatar
I checked my right shock mount and it has the huge plate like Bruce chopped on his. Bruce, did you ever find out what the thing is for?
Must have been to mount or to brace something else that could be mounted.
Regardless, I will either have to replace it or chop it. If I purchase an 04' or 05' right shock mount is it an easy bolt on? Will I need to relocate the E-brake cable mount?
Thanks,
David
David Dunbar
Tomball Texas
Dunbar is offline
Old 05-04-2007, 12:29 PM   #28 (permalink)
Thanks,
David
Yes it is an easy bolt on and yes you will have to reloce the E-Brake loop
Not sure if the same wire loop was reused, I think not since the old one just had a small hole in it and I think the new one mounts to the shock bracket bolt, that is much larger.
Just ask your parts guy if the loop on an 02 is differnt from an 04.
Do not confuse him with any parts from an 03 as that is when the rear sway bar evoloved.
I you have to buy a new 05 loop I can look at mine and or post a pict.
No one ever knew what that huge plate was for other than the one hole for the E-brake loop of wire. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
You have to remove it to cut it back when I did it there was no New-Old. So you might as well buy a new one.
NOW! be sure to post ALL the updated part numbers, AFTER they all fit one your truck. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
If your dealer will give you 20% off like mines does you should come out less than the Helwig with no shipping. Just buy all the right bolts and nuts from Ford as well, I did not list those but Ford does not get you to bad on fasteners and you know they will fit.
Bruce
Old 05-08-2007, 12:14 PM   #29 (permalink)
221
I have an 04 that I belive has the sway bar on it. What guys are saying is take this one off and replace it with a beefier 30 mm bar either OE or helwig correct?
221 is offline
Old 05-08-2007, 12:54 PM   #30 (permalink)
If you have the factory bar 24MM just under an inch then
all you need is the 30MM bar it comes with the new bushings you need
Cost is about $60 with a little discount.
looks like the price may be down according to 1stFordparts
The Helwig will not fit the OE set up you have; just use the part number above.
I did a post spring-summer of 05 on this swap when I did the second time on my 05
Bruce
