HELP Front Coil springs broke! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-13-2009, 02:28 PM   #1 (permalink)
Hello,
The right front coil springs on my 2wd Excursion has broken. Ford tells me that there are none in existence and that it is an obsolete part. They (Ford)referred me to the Green Sales Company who has nothing.
Any ideas?
Thanks so much for your help
Jason
Jason Air Force is offline
Old 10-13-2009, 02:49 PM   #2 (permalink)
There are apparantly several different codes for these JA vs KA vs LA and I have SA.
What are the differences and can I use any of these other than the SA that came on it?
Thanks again - my mechanic is at a loss on how to help me
Old 10-13-2009, 03:53 PM   #3 (permalink)
tried powerstrokeshop.com or fabtech? i am sure these are not obsolete but havent had to search for them. How did it break? also fill in your signature with yr, model etc.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 10-13-2009, 05:51 PM   #4 (permalink)
There should be plenty of 250/350 front spings that would work.
Sounds like the J K And L are 250/350 codes
there were likely 3 for the front like RA SA and TA
V8, V10 and Diesel
get the spring code for a crew cab with the same equipment and engine.
they should work fine.
Give us more info like year and engine and we can help more.
What is your code???? you can find it on the drivers door sticker
in the lower right you will see the letters:
SPR
XX YY
the XX is the front and the YY is the rear
Bruce
I may have 2WD sring code info but I need the year.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-13-2009, 06:08 PM   #5 (permalink)
Coil springs
Thanks for the help,
It is a 2003 X with a 6.0.
YC35-5310-SA - I think this is the code. If so then Ford can not get me any and no dealerships have them in stock (according to them).
Also I checked Fabtech and they have some as long as you go with the 4in lift.
2003 Ford Excursion
6.0 Powerstroke
95,000 miles
2wd
Old 10-13-2009, 06:43 PM   #6 (permalink)
FordPartsDiscounted.com lists them as available on their website.
2001 excursion 2wd psd auto 3.73 ls. zoodad mod,ccv mod.,hm tymar,hellwig rear anti-sway bar,mbrp 4inch turbo back,superchips,aih delete
ibmer is offline
Old 10-13-2009, 06:54 PM   #7 (permalink)
$40 cheaper at powerstrokeshop.com but they show them as available.
Again OP how was it broken as I have an 00 2wd in the family.
TXANGLER is offline
Old 10-13-2009, 07:14 PM   #8 (permalink)
Don't know how it happened, no specific event. I recently began towing a 33ft travel trailer but have had no problems towing and while we thought it occasionally made an odd noise on that side we think it has been broken for a while, and have towed with it like that.
2003 Ford Excursion
6.0 Powerstroke
95,000 miles
2wd
Old 10-13-2009, 08:45 PM   #9 (permalink)
Thanks my dads X tows at 30TT. I will let him know to keep an eye out for this.
TXANGLER is offline
Old 10-13-2009, 11:03 PM   #10 (permalink)
What is the one or two letter code on the door sticker?
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 11-06-2009, 04:02 AM   #11 (permalink)
i also experienced that obsolete ford parts but still i tried to search that parts online and there are many sites that still offered obsolete items with low cost of shipping..
pat63 is offline
