Old 07-20-2004, 08:50 AM   #1 (permalink)
Help with Hellwig
OK, I installed the Bilstein Shocks, they were not to much of a hassle. The rear took about 5 minutes each, the fronts were about 25 mintues each.
Now I want to install the Hellwig Rear Sway Bar and I don't know where to start, the instructions SUCK.
I have had the X up on my lift and have looked at everything back there and it just makes no sense.
I have looked at most of the Hellwig posts and the pictures and still can't seem to make it out. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Mike
'00 White XLT with PSD Badging, K & N Filters, PPIII
vettmike is offline
Old 07-20-2004, 09:08 AM   #2 (permalink)
Re: Help with Hellwig
Check my pics in my sig and see if it makes any more sense. It is pretty easy once you the throw the instruction away.
jward is offline
Old 07-20-2004, 09:52 AM   #3 (permalink)
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] Sad but very true. I have sent Hellwing many notes and have talked to them. They could offer someone on this site something to write up some install instructions. This site alone has problem been one of there best ads for Excursion sway bars.
John [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 07-20-2004, 10:21 AM   #4 (permalink)
Here's what I did.
Just thread the sway bar in place(end tabs go forward and the bar goes in front of the axle). Remove the old U-bolts(remove and replace one at a time and keep shocks compressed [img]/ubbthreads/images/graemlins/smile.gif[/img] ). Put new U-bolts and the new plates in place. Align the outsides and bolt her up. It's about that easy. Once you put the bar in place it makes much more sense.
Pictures do help immensely especially with the end tabs!!
-2000 Excursion Limited. 2WD. White with tan. Hellwig rear anti-sway bar. Bilstein shocks. Rear air bags.
2000 VW New Beetle TDI
2005 VW Passat TDI...totalled
2006 VW Jetta TDI
DR.billZ is offline
Old 07-20-2004, 01:35 PM   #5 (permalink)
Thanks Guys,
Since I just installed a 10,000 pound 2-post lift in my shop I will put the X up again and see if I can figure it out. I assume I should be able to install the bar and forward hanger and then put it on the ground and attach the bar to the hanger, in the pictures it appears that the links were cut, do they need to be cut, if so, how much?
Mike
vettmike is offline
Old 07-20-2004, 01:55 PM   #6 (permalink)
CHPMustang's Avatar
I didn't cut the links on our X as when I had the blocks put in I had to adjust the links a couple notches to prevent the bar from tapping the rear axle pumpkin.
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 07-20-2004, 03:05 PM   #7 (permalink)
I cut 1 hole off ea. end of ea. link so that the arm was somewhat parallel with the frame but not so much that the bar would hit the differential in a compression mode. I hope that makes sense. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
jward is offline
Old 07-20-2004, 03:29 PM   #8 (permalink)
I would have had difficulty installing the Hellwig without the pictures here on TDS. I used my floor jack to keep the shock brackets in position.
2002 X Limited PSD 4x4 - Mineral Gray, WeatherTech floor mats, cargo liner, and Weather Visors, Ford "Tire Organizer", Silverstar headlamps, Hellwig rear sway bar, "Steveracer" fog light mod, TTM, XM Roady 2, completely stock drivetrain. Tow 24' Osprey Fisherman on Long AL2570 trailer.
overcurrent is offline
Old 07-20-2004, 03:43 PM   #9 (permalink)
mike650's Avatar
We did not do any cutting during the rear Hellwig installation. I guess it's up to you. Your going to love the handling when your installation is completed. How's the factory paint job on your sway bar and hardware parts? Do you find it as good as the directions? LOL
Take care!!
2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002
Improvements: 2002 PSD Badges, and lot's more!!
mike650 is offline
Old 07-30-2004, 01:26 PM   #10 (permalink)
My Photos: (25)
Actually I think it depends more if 2 or 4 wheel drive. I didn't have to cut for my 4x4, but have read from others with 2x4 having to remove a hole or two off the end links.
2003 Excursion EB 4x4 7.3PSD Rear swaybar X-Monitor
Prodigy
xmechx is offline
Old 08-01-2004, 11:56 AM   #11 (permalink)
mike650's Avatar
I think every situation is going to different and it's going to be up to the owner. JWARD has a 4x4 X and he cut one link out. See his posting two responses above my original one on this same thread; JWARD also includes links to his pics with all of his postings. Personaly I think I could have removed one myself but chose not to. I am looking at your pics and your setup looks just like mine. Nice job on your pictorial!!
mike650 is offline
» Sponsor Links
»Garage Storage and Cabinets
