Old 04-24-2007, 11:47 PM   #1 (permalink)
Help!! Trouble getting second row seat back up!!
The second row seat has jammed and I can't put it back up!! [img]/ubbthreads/images/graemlins/eek.gif[/img]
This thing got stuck once before and I cleared it but can't for the life of me remember what I did. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I have the leather limited edition but I don't think it is any diffrent from the cloth units!
Thanks!!!!
Todd in Md
'01 Excursion Limited in Maryland State Police Green with SPDiesel SIIIe module,solid state T/C SSEBV Controller,SP Intake,MBRP 4" turbo back, Coolant Filter,Pricol Gauges,6.0 trans cooler, BTS Cconverter,265/75 Revos L/R 'E', Amsoil Dual remote mount oil filters, Amsoil 15/40.
NoPlugs is offline
Old 04-25-2007, 12:06 AM   #2 (permalink)
Re: Help!! Trouble getting second row seat back up!!
It's stuck because the seat cushion isn't pushed far enough forward. Push it forward, and the seat back will come right up.
Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato
2001 Excursion 4x4, v-codes, Western Diesel guages, AIS with fender sleeve & zoodad, MBRP 4" exhaust, Tru-Cool Max tranny cooler, 203* thermostat, BFG AT 285/75-16's, RS9000X's, Rancho steering stabilizer, tightened steering box, Hellwig sway bar, Air-Lift springs and compressor, Draw-Tite trunnion bar WD hitch, SUVlights.com harness, PIAA driving lights with homemade harness, Cobra 25STWX radio
ScaldedDog is offline
Old 04-25-2007, 12:21 AM   #3 (permalink)
Maybe that's it Mark but I thought I gave that a shot and it was all the way forward.
I'm stuck at work without it right now and will try that tomorrow morning when I get off.
I'm installing new front powerslot Cryo Rotors and hawk pads as well as bilsteins tomorrow on it.
Thanks!
By the way, how do you like that Helwig sway bar?? I tow a 10K 31' TT and I hear they work well on reducing body roll.
NoPlugs is offline
Old 04-25-2007, 02:55 AM   #4 (permalink)
Try it again. I've had things like water bottles get trapped between the floor and the seat bottom, so that I really had to push it pretty hard to get it forward enough. I guess it could be something else, but this problem is really common.
I love it. The hardware that came with it was worthless, but that's easy to fix with a trip to the hardware store. They really do make a big difference.
Good luck with your projects! BTW, <><, too. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Mark
Old 04-25-2007, 03:56 PM   #5 (permalink)
Move the front seat up and out of the way
I know it sond wierd but just do it
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 04-25-2007, 06:26 PM   #6 (permalink)
FamilyRide's Avatar
If none of that works, also check the rear seat-belt guides. I've had them move just enough to slide into the seat keeping it from moving.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 04-26-2007, 02:10 PM   #7 (permalink)
FIXED!!!!!!
Thanks Mark, Scott, Bruce, Familyride!!
The problem was threefold. [img]/ubbthreads/images/graemlins/shocked.gif[/img]
#1 Playstation case stuck below seat!! [img]/ubbthreads/images/graemlins/phoney.gif[/img]
#2 12V Cellphone cable got pinched and cut in half LOL!!! [img]/ubbthreads/images/graemlins/eek.gif[/img]
#3 WAter bottles and soccer cleats and socks stuck in seat belt guide!!! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Thanks again! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I'll now need to clean out the travel lodge THANKS ALOT LOL!
I'm sure you guys have never had stuff like this (not).
Todd
NoPlugs is offline
Old 04-26-2007, 02:41 PM   #8 (permalink)
Re: FIXED!!!!!!
Ain't having kids great?!!!
(edited for spelling)
2005 EXCURSION!! XLT V10 Silver Purchased 10/8/05 19920 Miles.
Heated tow mirrors, Hood/window deflector,Ford rubber mats, Firestone bags/air source kit, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Curt front reciever, 6 disk Visteon stereo, 6 disk changer in console, X-3 AIC, door lights,OEM Fog mod, volt/tran temp gauges,skid plate.
housedad is offline
Old 04-26-2007, 07:04 PM   #9 (permalink)
Re: FIXED!!!!!!
Ain't having kid great?!!!
YEP!
I just took all the Junk out of mine this morning so the car wash could clean it up. It is now in PU truck mode for the weekend hauling stuff for the younger daughters graduation from UNCCH in two weeks.
If you hve not been there and done that then; What the heck are you doing with an X anyway?
Bruce
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 04-27-2007, 01:07 AM   #10 (permalink)
Re: FIXED!!!!!!
Glad you figured it out. When I had the same problem, I got the answer the same way you did: By posting here! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] It's a great board.
Mark
» Sponsor Links
»Garage Storage and Cabinets
