Oh, it just keeps getting better. Over the winter the narrow rigid a/c line that runs from the engine to the rear unit wore a hole in itself from rubbing against the leaf spring bracket. Had to come from the factory that way, but 5 years and 140,000 miles means it ain't under warrenty.
Doesn't look like there are any joints in this line between the engine compartment and back inside the truck in the rear a/c unit. The line's probably over 20 feet long, with bends and a U turn over the front wheel. AAAAARRRRRGGGGGG!!!!!!! [img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/mad.gif[/img] Hubs x 2, ball joints x 4, front springs, steering wonder issues, penion bearing, warped roters, speedometer, broken down seat, ABS, and now the a/c line. This truck has cost more in the 2 1/2 years I've owned it than any other I've ever had. It's a good engine, but the rest of the truck is starting to tick me off.
Sorry for venting. Has anyone replaced this line, or have any suggestions, or knows of a way to repair the hole in the line? Can the hole be cut out and the ends flaired like a brake line? So that male/female fittings can be used to attach the new part.
I rarely see a metal line that can't be repaired. Its hard to say what to do without being able to see it. Is it steel or aluminum? Is the hole big enough and in a location that would cause concern about contamination?
"Contamination"? Not sure what you mean. I presume this is a high presure line, and that after the hole is repaired or replaced, the a/c unit becomes a sealed loop again. The hole is under the truck body, on the passanger side, where it runs by the front leaf spring bracket on the rear axle. Found the hole from the die dripping out after the local garage tried to recharge the a/c.
Are you able to put a patch over the hole, or cut out that section of line and splice in a new section?
If it was the large one (like 5/8" or so) you can just patch with hose.
That way you can cut out the secton with the hole and nany dirt with it.
They were steel in my van, I know cause after 9 years they were getting fairly rusty And I though I might loose one. I did have one of the steel heater lines rot through.
Sorry you have had this much trouble, 3 years and 100K and minimal/negligable repairs on our X, Thinking more about an 05.
Good Luck
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
The Ford replacement lines come in many pieces but have to replaced as a assembly. You need to cut the old lines out to remove them unless you want to remove the body.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
