Old 10-16-2005, 08:57 AM   #1 (permalink)
Hood release???????????????????
I have an 04 X and the hood release stopped working. Seems like the cable stretched. Is this common? The seat release cable had to be replaced also. It would not release are they using rubber?
04 Excursion
01 Dodge 3500
99 Corvette Road Race
96 Corvette Grand Sport
84 GMC 7000
DOGdiesel316 is offline
Old 10-20-2005, 01:30 PM   #2 (permalink)
Re: Hood release???????????????????
I haven't had mine long enough to respond but I will give ya a bump to the top and maybe someone else can respond. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
XinAZ is offline
Old 10-20-2005, 05:46 PM   #3 (permalink)
Been around here for a while, had an 02 that I sold w/110K on it
I don't think I have ever read about this problem.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-21-2005, 07:53 AM   #4 (permalink)
Same here. I do not have that kind of mileage, but I have never heard anyone have that problem to now.
John [img]/ubbthreads/images/graemlins/smile.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 10-21-2005, 12:04 PM   #5 (permalink)
Not only never happened in either of my 02, 03, & 05 Ex's....
but never heard it happening on ANY of the websites thus far...
JohnBoyII is offline
Old 10-21-2005, 01:52 PM   #6 (permalink)
way back in 92 they had issues with it possibly freezing and getting stuck, but not stretched.
powerboatr is offline
Old 10-21-2005, 01:55 PM   #7 (permalink)
FamilyRide's Avatar
Agreed, never heard of it.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 10-21-2005, 05:30 PM   #8 (permalink)
Well there you have it! it is working fine.
Must be operator error! [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Sorry we could not help but this is a new one just have to get it fixed.
Can anyone help him get it open so he CAN FIX IT????
Cut into the cable under the truck???
Who has done a grill replacement? can you get to it that way?
Bruce
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 10-21-2005, 06:15 PM   #9 (permalink)
Mine did this just the other day. At first I thought I just didnt pull hard enough. Another tug didnt help. I ended up just lifting on the hood and it popped up. Havent had a chance to look into whats causing it yet though. Ill have an answer this weekend.
989171 is offline
Old 10-24-2005, 12:40 PM   #10 (permalink)
This is what comes to my mind also, that maybe the release is working, but the hood is popping up on it's own. I had this problem on my old S10 Blazer. Opening the hood was a two person job. One to hold the lever, the other to pull up on the hood. Actually, I think I remember my X doing it once also. I suggest trying it with two people, one lifting the hood, one pulling the lever.
Keep us posted.
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline
Old 10-24-2005, 05:01 PM   #11 (permalink)
I had the same prob. It was a two person job requiring some pushing & prying (fingers, no tools!) on the hood, while working the lever. After it popped open I lubricated the latching mechanism, slammed it shut and now works like a champ.
Hopefully your fix is this easy. Good luck.
BookBoy is offline
Old 10-24-2005, 10:45 PM   #12 (permalink)
Had the exact problem on my '00. I had to pry a big screwdriver under the hood by the release and and pull to get it to release. Took it to the dealer to change oil and advised them I had trouble opening hood. When I picked it up, they said the "catch" was bent a little, so they straightened it and lubed it. Not sure I got the real story, but never had any problems after that. Yes, they charged me for like .25 of an hour, but I was going to break the dang thing off using the screwdriver. Very frustrating condition.
'05 LTD PSD 4x4, mineral grey, born 02/05 (with '05 Engine), delivered 3/05. 2nd row buckets, tinted front windows, PSD badges, Fabtech 3.5" spring relocation lift kit, F350 rear blocks, Rancho RSX-9000's, BFG 295 AT's, Catch-All mats, Lund Vent Visors & Interceptor, 4 screen VCP/DVD/TV system w/ multi-channel audio, Uniden scanner & Passport 8500, next up: 1500/3000 watt Vector inverter, Clifford Matrix RSX3.5 remote start & alarm
'01 Ford F150 SuperCrew King Ranch 4x4, stock for her...
Sold: '00 X LTD PSD, 93k virtually trouble-free miles
jderner is offline
Old 10-26-2005, 05:31 PM   #13 (permalink)
Sorry I haven't been back in a while. I sprayed it with some PB Rust Buster and seems to work now. I hope it continues to be so compliant [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. I have a 96 Corvette and that locked itself down due to cable failure. I ended up making a tool myself to open it. No body could get it open. I was ready to take a sawzall to the hood.
04 Excursion
01 Dodge 3500
84 GMC 7000
» Sponsor Links
»Garage Storage and Cabinets
