Horn problem relay location? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 07-08-2009, 05:28 PM   #1 (permalink)
Washed the interior of the truck the other day when all of a sudden the horn starts blaring.
Finally got the battery wires off just as the fuse blew.
Put in another fuse but when I hit the horn switch now it just blows out.
Could this be a bad horn relay?
Any idea where its located?
'02 Diesel Ex
'02 PSD LTD Ultimate X Rancho17000's/Ucodes/SkyjackerDual steering stabilizer/Addco Swaybar/REVO'S/Stuhl billet grille/17"Ford Air Horns Behind the grille!
ford_x_3 is offline
Old 11-20-2009, 04:54 PM   #2 (permalink)
i have a similiar situation---does anyone know where the horn relay is?
thanks
grillmastertoo is offline
Old 11-20-2009, 11:04 PM   #3 (permalink)
fathers 00 X had same issue blew fuses burned up horns, relay checked Ok, clock spring OK. Horn switch was shorted located INSIDE the airbag assembly. 800 bucks later he passed safety inspection. That hurt!!
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
