Re: Hour meter for my Ex.
You can buy one at most "big" truck supply stores. Summit Racing www.summitracing.com has an AutoMeter hour meter for $48.00 and a VDO for $32.00. Northern Tool www.northerntool.com has a "no-name" hour meter for $24.99
Just hook the ground wire to a good ground under the dash and the hot wire to a fuse in the fuse box that is hot when the truck is running. I even put one on my John Deere garden tractor to keep up with the 25 hour oil changes.
Hope this helps!
Firefighter9208
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
2009 Chevrolet Traverse(wifes car)
2004 Keystone Cougar 314EFS
2004 Kubota M4800 W/Bushog Loader
1969 Mustang Mach 1 351W
2010 Kawasaki TransMule Diesel
