Houston 4x4 (7.3) suspension modifications - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-08-2009, 06:45 PM   #1 (permalink)
I am looking for someone in the Houston area that has made the front and rear leaf spring modifications on a 4 x 4 Ex (7.3 liter). I would like to visit privately with you and possibly see exactly what and how it was done. PM me. Thanks.
01 Excursion, 4 x 4 Limited, 265/75/16 Firestone Transforce HT maintain 72 psi front- 70 psi in rear, Superchip, 3.73 rear end, Airbags front and back (10-15 psi) 275,000 miles.
01 F-350 dually, 4 x 4 Lariat, Hypertech chip, AFE air intake, 4 inch MBR Exhaust, rear air bags (25-50 psi) 110,000 miles.
01 Excursion is offline
Old 11-08-2009, 11:08 PM   #2 (permalink)
bpcheramie's Avatar
I did a complete spring swap. See if you can find a user by the name of Dunbar. He might be able to help you out.
Brent
bpcheramie is offline
Old 11-09-2009, 08:35 PM   #3 (permalink)
texaspsdx's Avatar
I would check with Off Road Unlimited on Westheimer. Welcome To Offroad-Unlimited.net Your professional Offroading Source
Great folks to work with.
Ron
2000 Excursion Limited 2x4, 4.10 w/Detroit TrueTrac, PSD/Auto, ATS turbo shroud,Badging, 4" exhaust w/AeroTurbine 4040XLL, AIS, HX crossover, ISSPRO gauges/A-Pillar, SuperChip 1705, Pre-Pump & In-Tank Mod, Banks TransCommand, ZooDad, Baldwin Oil ByPass, Ford AIC, F350 rear springs, Helwig Rear Sway Bar, Michelin's LTX MS,
1983 Avion 34V - 35' travel trailer,
Hensley Arrow No Sway Hitch
texaspsdx is offline
Old 11-13-2009, 10:25 PM   #4 (permalink)
Dunbar's Avatar
Real name too.
I did V codes on the front and modified F codes on the rear. I had DI put them on.
I live in NW Houston between Tomball and Cypress. Shoot me a PM and I will give you my phone number for questions or to see the results.
Dunbar
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, Tymar DIY, Vcode & modified Fcode, Helwig, Inappropriately valved Bilsteins, Isspro 3 gauge w/ windshield mount, DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler,
BTS Transmission, DI Up pipes
Tomball Texas
Dunbar is offline
Old 11-15-2009, 02:10 PM   #5 (permalink)
This is a really simple mod ... check out my pictures using the link in my signature. No sense having a shop do the work if you can turn wrenches and have some free time on a weekend. I did mine by myself.
PM me if you need additional information .
2002 7.3L Excursion, DIY BHAF 6637, 08+ Al Rear Dif Cover, F350 X-springs and blocks
http://s165.photobucket.com/albums/u42/rkik/Excursion/
rkik is offline
Old 11-18-2009, 10:12 AM   #6 (permalink)
boertje's Avatar
My Photos: (29)
I did the V code and modified F code on mine myself. Really its not that bad of a job. There are some pictures in "My Photos"
2001 VW NB TDI speed.
SOLD: '02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads, IH CPS part # 1826899C93 (original CPS).
boertje is offline
