Old 02-23-2007, 10:10 PM   #1 (permalink)
How big can I go?
Wondering what the biggest size tires I can run on stock rims without doing a spring mod or lift kit. I just want a beefier look with improved traction. Also any recomendation on good tires for traction in mud with cood highway wear. Thinking BFG's. Thanks
'01 Excursion, Edge Evolution waiting for more money for more toys
powerstoker is offline
Old 02-24-2007, 12:56 AM   #2 (permalink)
Re: How big can I go?
I would recommend the BFG AT's. I have 285's on both trucks. No lift but: I replaced the front springs on the X with some off a F350. Very good improvement and not to bad of a job. If you do not replace the
D-code factory X springs you can fit 285/75/16 BFG but may have some minor rubbing issues. Usually the front/corner edge of the black plastic airdam under the bumper. Also the fender skirt may touch in the rear of the wheel well. If you want to avoid rubbing and no lift stay with the 265/75/16.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 02-24-2007, 03:25 AM   #3 (permalink)
Do you have a 2 wheel drive or 4x4? I had 305/70-16 Goodyear wrangler ATS's on my stock 02 4x4 with no issues at all.
95 F-250 SC LB 4x4 XLT PSD E40D 4:10,SCMT 60HP, 4" Superlift W/ B.F.Goodrich all-terrain 315/75-16's.
02 X Limited Ultimate,4x4,PSD,SCMT 110HP,6" Superlift W/BFGoodrich 315/75/16's on 16x10 polished aluminum wheels,K&N Filter,polished Billet Fuel Door, T-Rex polished Billet grille.
AHankal is offline
Old 02-24-2007, 10:59 AM   #4 (permalink)
FamilyRide's Avatar
285's here with absolutely no rub or touch anywhere.
Every one is different. Some can go 295's without rubbing, some can't. Some can actually go 305's which is rare. The problem is the skinny OEM wheels. Even my 285's don't fit like I'd like them to, with the tread even on the ground all the way across.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 02-24-2007, 12:24 PM   #5 (permalink)
I tried to up the tires to 285's when I first got the X...waste of money IMO The X just begs for a wider rim, 9-10" the stability a wider rim will give you is worth every cent. I also feel that the X MUST be lifted with SD springs, 30mm rear sway bar and good shocks to make it safe.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 02-24-2007, 03:48 PM   #6 (permalink)
It is a 4x4.
Old 02-24-2007, 08:06 PM   #7 (permalink)
If you want to change rims, a 305-50-20 on 8.5x20 inch rims will fit stock on a 4x4.
Garry K
2005 EX LTD 4x4 PSD, V's w/ Summit "gas" leveling kit and modified B's, Radius Rods, 30mm sway bar, Eagle 114 20's w/ 305-55-20" Open Country AT's, Prodigy, Dual-Cam HP hitch, all Black (Secret-Service-Edition)The Ex The Harley EX Road Armor Front Bumper with custom Aluminum winch-hole cover-plate. http://i33.photobucket.com/albums/d9...6/DSC01629.jpg
2001 Nomad 308 (32" w/ 14' Slide) Bunkhouse
4 kids and love to travel and camp!
2001 F350 Dually 4x4 4dr 7.3 6spd 180k and still running strong!
garryk6 is offline
Old 02-25-2007, 05:25 PM   #8 (permalink)
For a year I ran 295/75/16 BFG AT's on 16x8 AR Atlas rims with no rubbing ever.
Picked up a set of 265/75/16 Ravo's on 16x8 Centerline rims and they rub. Paid $200 for the set with 200 miles on them! Garage fire burnt the top tire.
The overall tire size is a good inch shorter on the Ravo's but the rim offset causes the tire to rub.
Not sure which tires I like better yet. First set of BFG's got me 80K miles. Second set had two blow outs by 40K miles but the other two have an easy 70K miles on them.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 02-26-2007, 10:00 PM   #9 (permalink)
Is that using the same back spacing as my stock Limited rims?
Old 02-27-2007, 02:13 AM   #10 (permalink)
I had 285's for a while and never rubbed.
As for a tire, I'm a firm believer in the Bridgestone Dueller Revo AT's!!!
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 265/75/16 Revos, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120).
1999 BMW 540i, 6 speed, sport package, totaled.
2000 BMW 540i, 6 speed, sport package, not totaled.
jnyost is offline
