How can I disable the reverse sensing system for extended periods of time?
In order to disable the RSS on my '04 X the dash mounted button needs to be pushed every time you shift into reverse. I do not look forward to having to push this button every time I want to back up my X when towing as the RSS will need to be shut off to back the trailer.
Is there a way to make it so the dash mounted button stays in the "off" position when pushed until it is pushed again to reenable the RSS? It would be great to have it stay off while the truck is running and reset back to on when the ignition is turned off.
04/04 PSD X 4X4, Oxford White EB, October '03 build, all options except 2nd row captain's chairs and chrome step tubes, stock drivetrain, no flashes (still have quiet idle and original tow/haul), Donahoe 4.5" Spring Hanger Lift, High Angle Driveline CV Driveshaft, American Racing 17X9 Chrome Chamber Rims, Toyo 35X12.5R17 Open Country M/T's, PSD Badges, Yakima MegaWarrior roof rack with extension and King Cobra bike carriers mounted outboard, AMP Research Power Retracting Running Boards, Brakesmart Controller, Radius Rods, Firestone air springs with on board compressor, C-Bet'r mirrors, Marinco block heater plug in front bumper. Towing 28 ft. Sunline TT with slide room (7500#).
2001 Dodge RAM 1500 Quad Cab, Intense Blue/Silver two-tone, 4X4, 360, auto, 4.10 gears, Off Road Package, Daystar 2" front lift, 285/75R17 MT/R's, K&N Intake, Gibson stainless cat back, Line X spray in bed liner, Firestone air bags w/ on board compressor. Boss 7'6" plow.
Re: How can I disable the reverse sensing system for extended periods of time?
It would be nice if a push turned it off once and a push and hold for 5 seconds or so would keep it off, just like the OD button.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Maybe it would be possible to jerry rig an on-off switch,perhaps there's a similar Ford switch that's available that would work.
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
I'd like it if it worked like the OD button .press it and it's "off" until you turn it back on or shut down the engine. That would solve the problem for me. (it's a major pain when backing a trailer). Even better would be for it to be disabled anytime the brake controller detected trailer brakes!
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
I agree totally,it should stay of-off even when the truck gets shut off,hmmm,I got an idea'r [img]/ubbthreads/images/graemlins/wink.gif[/img]
I'm going to follow up on this.
Swap the the seat heater switch and the RAS switch? [img]/ubbthreads/images/graemlins/laugh.gif[/img]
We tow a few times a year and yes it's annoying hearing the beeper not beeping just a solid loud tone similar to Jim Carrey's screech in Dumb and Dumber [img]/ubbthreads/images/graemlins/grin.gif[/img]
Now that's annoying [img]/ubbthreads/images/graemlins/smile.gif[/img]
One way or another I'll fix the problem without unplugging the sensors or snipping anything.
BILL
Hey, in the qwest to help bill rid us of this annoyance I have put the wiring diagram up: [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
Looks to me like the disable is a momentary switch that grounds the parking control module which is "reset" anytime you switch out of reverse. I'd imagine that a switch there that kept the wire grounded would disable it until it was ungrounded, but I'm definately ignorant in this area and would hate to screw up anyone's parking aid control module.
Regards,
Dave
That would be easy enough. Install a holding relay inline with the disable switch. A holding relay will stay "made" until power is removed from it. In other words it only needs one signal to close (and stay closed), it doesn't need a continuous signal. Or replace the momentary switch with an on/off switch, but then you would loose the P logo on the switch.
Just looked at the schematic for a 2003 X parking assist system.
The PAM (Parking Assist Module) is located in the Rt Rear a/c compartment. The system "arms" with the reverse light circuit. Looks like the way to disable it would be to interrupt the reverse light imput at pin 9 (BK/PK)on the connector with a switch or by wiring in a relay to cut that imput. The speaker is in the rear right side pillar,so following the wire from the speaker should lead to the PAM.
The switch could be put in the compartment or wiring run to locate it on the dash.
Nat
[img]/ubbthreads/images/graemlins/warmsmile.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
PS The other wiring diagram shown above was just a block diagram.
2005 F-350 CC SWB SRW Harley; 2004 F-350 Chestnut/tan 4X4 King Ranch CC SWB SRW 2004.25 6.0 PSD
Past PSD's All 4X4
1999 F-250 SC SWB 10-98 build
1999.5 F-250 Lariat
2000 Excursion Limited PSD
2002 F-350 CC SWB Lariat
2002 Excursion Limited Ultimate Premier
2004 Excursion Limited 6.0 POS
Son's F-250 SC SWB PSD
2005 F-350 King Ranch CC SWB 6.0 POS
Then it would be real easy, just put the switch back there. Your there anyway hooking up the trailer. Hook up the trailer, hit the switch, un-hook, turn it back on.
