Re: How can I disable the reverse sensing system for extended periods of time?
I suggested to the wife when we first got the Excursion in June 2002 why don't I just unplug the beeper by the back door and she said uhhhh,no.
BILL
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
To make this more automatic you could cut the power lead to the center pin on the 7 pin connector and splice in a lead that would connect to the PAM to keep it grounded (most trailers don't use the center pin of the 7 pin connector = Reverse Lights). This would mean on the trailer side either adding a wire to the center pin and grounding to the frame or jumping to the white terminal (Ground) or you could take the yellow lead from the trailer pig tail and grounding it to the frame or the white wire (Ground). Of course this still requires snipping but it would make the PAM "Off" while the trailer is conncted and then "On" again when the trailer is DIS-Connected. If your trailer has reverse lights then maybe another wire could do the trick.
2002 PSD Excursion XLT Premium 4X4 (<font color="green">Aspen Green</font>)
Trailer Tow Mirrors, Rear Sensing, Adjustable Pedals, 6Disc CD, Aftermarket Rear Seat Entertainment System (VHS, Wireless, 7" Screen), OBX sticker, Molded Front Mud Flaps, Helwig Rear Roll Bar
I just did this mod. It works great. I just added a switch on the rear right pillar. Doing it automatically when a trailer is hooked up would be nice also. But, I did not do this because I want to be able to disable when my motorcycle carrier is on the back also.
Beeper switch Here's a link to some pictures I made last year. I installed a switch that shuts off the speaker, and in it's place lights a small LED that I installed near the headlight switch. The LED flashes just like the speaker beeped.
2001 F-250 (pcm PMT2) ISS Pro EV tranny, boost, pyro gauges. TS Performance flip chip. Banks MONSTER exhaust, Maghytec rear diff cover, ITP H/X kit, Whelan 52" Strobe Bar, Fisher 8.5' Snow Plow, 3 Weatherguard tool boxes. HUTCH fuel tank mods, REMANFACTURED Ford transmission.
DPDT switch. the center 2 switch terminals connect to the signal output of the module, top 2 terminals go to the beeper/speaker, bottom 2 terminals go to the 12V Radio Shack LED indicator.
Has anyone tried this on an 04 particularly a pickup - sorry I am not and X man, [img]/ubbthreads/images/graemlins/shrug.gif[/img] but I do dually?. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I'm looking for the mod that when I push the off button it stays off and shows an off light unlit I push it again.
Thanks for helping if you can - Keith
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
OK Folks a little more help here. On my F350 the box and speaker are up under the passenger side kick panel. I found and disabled the speaker, but the off light does not light up on my 04. I did not pull the positive side to the speaker, but the Black/pink return line.
Now in looking at this I believe dmftoy1 suggestion to help keep the temporary ground permanent I am looking at doing this. Did anyone follow up on this. Per my 04 wiring diagrams it appears the momentary switch grounds circuit 1435 DG/VT to circuit 676 PK/OG. It appears a second switch jumped across these two wires is all that is needed. When closed it holds the ground. Any thoughts?
Goodies added.
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Pro Flap mud flaps
I've seen posts (and think Yoda had it done) that you can have the programming changed so that the dash switch will disable the sensors for a full key cycle (you won't have to keep hitting the button each time you shift into reverse).
My understanding is that the dealer has to hook up to the ECM to make this change and have avoided it as I do not trust them not to reflash. I have an early '04 with the quiet idle and original tow haul that I do not want to lose.
Try a search or maybe shoot a PM to Yoda.
04/04 PSD X 4X4, Oxford White EB, October '03 build, all options except 2nd row captain's chairs and chrome step tubes, stock drivetrain, no flashes (still have quiet idle and original tow/haul), Donahoe 4.5" Spring Hanger Lift, High Angle Driveline CV Driveshaft, American Racing 17X9 Chrome Chamber Rims, Toyo 35X12.5R17 Open Country M/T's, PSD Badges, Yakima MegaWarrior roof rack with extension and King Cobra bike carriers mounted outboard, AMP Research Power Retracting Running Boards, Brakesmart Controller, Radius Rods, Firestone air springs with on board compressor, C-Bet'r mirrors, Marinco block heater plug in front bumper. Towing 28 ft. Sunline TT with slide room (7500#).
2001 Dodge RAM 1500 Quad Cab, Intense Blue/Silver two-tone, 4X4, 360, auto, 4.10 gears, Off Road Package, Daystar 2" front lift, 285/75R17 MT/R's, K&N Intake, Gibson stainless cat back, Line X spray in bed liner, Firestone air bags w/ on board compressor. Boss 7'6" plow.
Correct. You don't need to do anything but visit the dealer and have it reprogrammed. Once you push it off it stays off until the next key cycle or you push it back on. I posted about it somewhere here. If I remember correctly it was in a service message from Ford So you know they only need to use their code scanner and not hook up the the mother ship. No chance of a re flash when they just use the scanner.
If I remember correctly I posted the solution in a seperate post.
Goodies added.
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Pro Flap mud flaps
OK folks in and out in two hours - actually less but I BS a lot as they did the work - they also replaced the vacuum pump for me that was a bit noisy. New dash on order due the the flaking surface
Special Service Message # 17815 - MULTIPLE VEHICLES -- PROCEDURE TO DISABLE REVERSE SENSING SYSTEM (RSS) FOR ENTIRE IGNITION CYCLE - SERVICE TIP.
To program the reverse sensing system (RSS) switch so it will disable the RSS system for the entire ignition cycle, rather than turning back on each time the transmission is put into reverse, Perform the following using the NGS service card (Green Card) Level 10 or higher
1 Select service bay functions
2 select PAM module
3 Select module option content (Hit Trigger)
4 Select Vehicle (Hit Trigger)
5 Hit trigger to highlight IGN or REV
6 Scroll to toggle between IGN or REV (Hit Trigger)
7 Select done which is soft key #8 (Programming Should Now Be Complete)
Effective Date 05/20/04
Say Good Night Hal...
Folks this works like a champ, so if it supposedly did not for you,(LawnWatcher) they did not do something right.
Happy UN-BEEPING the bleeping RSS.
PS: NO REFLASH IS NEEDED so if they say they must it is total BS
Goodies added.
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Pro Flap mud flaps
