I've looked everywhere to find this in the manual, and I'm sure that its probably in there, but how do you deactivate the dome lights in the excursion at the drive in. Can't even sit in the cargo area without those lights on!!!
2004 Ford Excursion 6.0 4wd all stock
The answer is you can't. You could put a switch in the line to disable the interior lights. I believe there is a single wire in the passenger kick panel area that if cut will disable the interior lights only. You will need to access a wiring diagram to find the connector and pin number.
jim
PowerTug
03 Excursion Limited PSD 4X4 3.73 LS
Build 3/20/03, C95 Injectors, Updated VGT, December 04 flash, Harpooned, Second Hot Water Shutoff Added for A/C, Updated DVD Entertainment Center wireless headphones, SiverStars, Fog Light Retro with 9005 SilverStars
Average MPG 17.5?, City MPG 16?, Highway MPG 19.5?, Towing Bass Boat MPG 17?
At the risk of showing my age, what "drive in" are you talking about? Do they still have drive in movies?
Anyway, to answer your question, if you climb over seats you can sit anywhere without the lights on. run the engine, turn off the key and don't open any doors. Climb over seats to get where you want to go. That should be fun for your girlfriend...lol No lights come on till you open a door. That's the way it is in my X.
01 Excursion, Ltd. PSD, EBM2, 4x4,arrived 11/22/00. Adds:TRUCK VAULT,Automate Alarm,3 Autometer Carbon Fiber Gauges on A Pillar,TTM.(Had to OH tranny at 60K on my dime for Ford's known defective mechanical diode problem)
after 10 minutes all power is cut to open switches until the pin is reactivated. This is how we camp in the X with the back open. Just leave the rear doors/window open and by the time the movie starts the relay will cut the juice.
Txangler
Unless I leave the key in to play the stereo [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
skygod Where is it the fuse? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Oley [img]/ubbthreads/images/graemlins/smile.gif[/img]
(Member Since April 2000)
2000 Excursion LTD, AXD1, TS 4 way tuned at BTS
3 WD gauges on the post with EGT in exhaust manifold and 203* T-stat
FleetGuard pre-pump spin-on fuel and Oil Guard by-pass oil filters and homemade ccv re-rout
{homegrown air intake} Western Diesel Ram Air scoop with HUGE 'TYMAR STYLE' paper filter,
ATS turbo housing W/Wicked Wheel on stock Garret, with Riley air charger boots
and intake heater deleted also Billet aluminum air intakes
{Exhaust is} Jardine 4" with 3 1/2" DP
{She's been} "hutcned" & "TT"d & HX oil crossover hosed
BTS/W V10 cooler, BD TorqueLoc, and Cyclone fan clutch, Mag-Hitec tranny & rear end pans
For ride and tow she's got the Hellwig rear anti-sway bar, Edelbrock IAS shocks,
Firestone Ride Rite over-loads, Tekonsha Prodigy, and Hensley Arrow
open the doors and then latch the offending latches, a small screwdriver will help. Don't slam the doors though with them latched because it makes a awfull noise.
Not sure I understand this. My interior lights go off when I turn the key. don't they stay off if the key is in the ignition?
I mean key in + back hatch open = lights on. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Oley
After I think it's 2 minutes, mine go out completly and the only way to get them to come back on is to close the door and I think I had to key cycle. It keep you from leaving a light or radio on without the key and leaving it.
Oley
Well you didn't SAY the back hatch was open [img]/ubbthreads/images/graemlins/shrug.gif[/img] ( big [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] back at ya ) [img]/ubbthreads/images/graemlins/smirk.gif[/img]
-2000 Excursion Limited. 2WD. White with tan. Hellwig rear anti-sway bar. Bilstein shocks. Rear air bags.
2000 VW New Beetle TDI
2005 VW Passat TDI...totalled
2006 VW Jetta TDI
This 50 cent switch from the factory would have saved us alot of headache.What were they thinking? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Hey, this ranks up there with the no light for low washer fluid.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
I forgot which one, but I just started pulling fuses until the lights went out. The stereo still worked. I pulled the fuse if the light stayed on I reinstalled it, eventually...bingo. Remember to have a flashlight or it will be a ***** to reinstall the magic fuse. I was at the drive-in doing it you can practice at home first.
Carl
