Old 10-13-2004, 07:56 PM   #1 (permalink)
How important is the LS option?
I have found an 05 PSD Excursion that I am thinking about buying and it has every option except the LS axle. How much of a difference will the LS axle make in the snow/rain/sand(beach)?
What might be my other choices of aftermarket limited slip units? or is it worth having the dealer install the LS.
Thanks,
Chris Turrisi
05 Excursion Ltd 6.0 - PSD Door Badges, BFG T/A KO 285/75-R16 Tires, C-Bet'r Mirrors, Catch-All Mats, ISSPRO EGT/Boost A-Pillar Mntd Guages, The Diesel Site Coolant Filter, Underhood Insulation & Weather Strips, Factory Mud Flaps, 22" Wipers, Valentine 1, Over Mirror Mntd ISSPRO Oil Temp, Oil Press, Volts, Diff/Tranny Temp Gauges, Custom Carling Switch Panel, KC back-up lights, Super-Springs, Custom 12v Power Outlets, Door Courtesy Lights, Vinyl Tubed Door Seals, Dynamat Extreme Everywhere, LED's in Door Handles, Amber Turn Signal Tail Lamps, PML diff & tranny covers, Fluiddampr, AFE Stage II Intake, LED TMI Tail Lamp & Rear Amber Turn Signal Bulbs, Cab Lights, Rancho Steering Stabilizer, RS9000 Shocks, V-Code Front & S-Code Rear Springs, 4.30 Gears, Edge Attitude, MBRP 4" Exhaust.
www.turrisimotorsports.com
cturrisi is offline
Old 10-13-2004, 10:31 PM   #2 (permalink)
FamilyRide's Avatar
Re: How important is the LS option?
Are you positive it doesn't have a limited slip rear? If so, ask them what the guy that ordered it that way is doing now, after getting fired! [img]/ubbthreads/images/graemlins/shocked.gif[/img]
In my opinion I wouldn't have it without one. Unless it's simply a grocery getter and highway cruiser.
They could swap it out for just a few $$ too......
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 10-13-2004, 11:09 PM   #3 (permalink)
With as heavy as an X is along with the torque of a PSD I wouldn't set foot on a beach without LS.
John
2000 Excursion Limited 4x4
265 Goodyear Wrangler MT/R's for winter
285 Bridgestone Revo's for the summer
X-codes and F-350 B-code rears
Polyurathane bushing kit
4" exhaust, intake, and gauges in the future if the price is right.
twoodballa is offline
Old 10-13-2004, 11:37 PM   #4 (permalink)
Couldn't agree more!
Greetings from Lynbrook and welcome aboard.If you need a good honest salesman to find an Excursion PM me.The guy I would recommend drove two hundred miles to get the X I wanted and delivered it to my home.Joe M.
My Photos
<font color="red">2002 EXCURSION, PSD, XLT Premium, 4X4, Medium Wedgewood Blue,8' Meyers E-Z Mount Snow Plow,14.1" rear LCD video monitor and DVD, FS2500 bypass oil filter, Mobile 1 synthetic ATF, Rotella T 5w-40 synthetic oil, Baldwin transmission filter, K&N filter charger with Zoodad mod., Banks Trans Command, Bilstein shocks, Rancho steering stabilizer, Hellwig rear anti-sway, XM Commander satellite radio, C-Bet'r convex mirrors, factory remote start, daytime running lights, Silverstar headlamps, "Xtra" reverse lights, Hidden Hitch front hitch receiver.Cabela's Winter Grill Cover by Fria</font>
1996 Ford Crown Victora P-71, white, blue cloth buckets, super clean and super fast.
2006 Subaru Forester 2.5X Premium(I highly recommend it in snowcountry)
2005 Gulf Stream Canyon Trail 29TEBH,with Reese D/C HP
JOE_M is offline
Old 10-14-2004, 01:00 AM   #5 (permalink)
Thanks,
I agree also,
One of the reasons I ordered my last four new vehicles, to get limited slip
When the rear end on my van went out I bought an Auburn Gear Limited-Slip from drivetrain.com and had a local shop put it in. It was better and had less noise than any ford unit I have had. ford wanted $1200 to "rebuild" my rear axle. With the new limited slip and new every thing except one axle, I think I spent 7-800 on it.
They have several brands with varius features most any would have an advantage over the OE unit.
I also agree why order a 4x4 with no LS it does not make sense.
I live where we have ice often and the OE unit does OK in sand and mud and it is OK in snow but on ice it's performance is well let's just say it is "limited"
If you found your perfect truck and $213 is dealer cost for the limited slip ask the dealer for a little more discount and get an aftermarket unit for $500 or so + install. Or see it the dealer will help out on the install.
Now that you brought it up, next time I might just put the $200 OE cost toward a real limited slip, or even a pair!
Hope this helps
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-18-2004, 08:03 AM   #6 (permalink)
Go with the ls. I have an 02 Explorer with straight axel and it scared the piss out of me when we lived in Ft. Worth. A couple of days of icy roads and trying to control my take-offs made me demand an ls on our X. Be safe. Go ls.
04 Excursion
Eddie Bauer
2X4, 3.73 Limited Slip
Engine Date: 08/29/03
Build Date: 09/09/03
donjuanmiguel is offline
Old 10-18-2004, 09:55 AM   #7 (permalink)
I didn't know it was possible to get the Excusion PSD WITHOUT limited slip! [img]/ubbthreads/images/graemlins/shrug.gif[/img] You learn something new every day....
Tailgate
2000 X PSD Ltd, 4x2, 3.73 LS, DP Tuner 16 position chip, Autometer gauges, AIS intake w/ Zoodad, Tymar H/X, Walker BTM, Dahl 100 fuel filter, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil all-around, PSD Badging, Extra Tint, Bridgestone Dueler Revo A/T tires
Tailgate is offline
Old 10-18-2004, 11:12 AM   #8 (permalink)
Follow-up:
The dealer was able to locate another 05 mineral gray excursion with all the options I wanted and the LS...
Thanks to all who responded.....
Chris Turrisi
cturrisi is offline
» Sponsor Links
»Garage Storage and Cabinets
