does anyone have any ideas where to look or know of anyone who can make my big beast lower to the ground.Just looking for a sportier stance.by the way it is 4wheel drive.the front is the only thing that is stumping me on this project. [img]/ubbthreads/images/graemlins/blush.gif[/img]
01 Ford Excursion 7.3diesel color matched with lime time green flames,22" chome rims,tinted windows,remote starter,bully dog tuner,4" exhaust turbo back,AFE stage II filter, HX mod,203t,AIH mod,big hd accuator,Banks compressor wheel,DI fuel gauge,DI fuel reg shim kit,stereo sytem with 4 monitors,ebpv mod
The front is already to low with no travel so unless you cut into the frame with a straight front axle you are out of luck
Most of us raise them at least 1.25 inches with U code springs in front
reducing wheel Dia is the only other option but then you would ahve to regear for sure or your MPG will go to heck in a big way
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Ok, dump the front end, fabricate A arms and drop spindles, fabricate the frame rail to go low and then stick the whole thing in a shredder as it is now scrap.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
First of al, is it a 4x4 or a 2 WD? I see 2WD's lowered (don't care for the look, 2WD's for that matter) but a 4x4 will be near impossible to lower.
Well thanks anyway guys looks like back to the old drawing board.I guess i will have to take the time and drive 2hrs to a custom fab shop to get there opinion. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Man that is SICK! [img]/ubbthreads/images/graemlins/eek.gif[/img] it sounds like they used stock spindles w/custom a-arms NICE! do you have the # to that plce since you live in cali where i used to live. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Going by memory, a rought guess is in the $7k to $9k range I believe
YEP! but i am still looking to build or have someone help with finding a way.They always say if there is a will theres a way i try calling and asking different shops on my spare time so who knows when i will finally find a way,but if i do i will post it. [img]/ubbthreads/images/graemlins/wink.gif[/img]
