I don't believe there is a limit on how many keys can be programmed. I have 4 sets myself. The only thing is that you have to have 2 working keys to program another.
__________________ Happy trails,
Rich Kimball
2000 F350 XLT CC LB SRW 6spd 4x4 Toreador Red @375,750 miles
'08 Center Console,Ranch Hand Grill Guard, SBC ConO clutch w/Kevlar Bushing, DP Tuner (60T,80E,120R),Gauges,Ford AIS,Walker BTM,AIH delete,HPX Oil Crossover, Wicked Wheel,TurboMaster WG Contoller,Riley BRV+,Riley Boost Boots,EBPV Gut w/mod. pedestal,IH Bellowed (donut less) UpPipes,Final Charge ELC coolantw/heater bypass,Riley Coolant Filter,Ford AIC,Centramatic Wheel Balancers,115gal Aux tank,Firestone airbags w/cab control. Oilguard Bypass Filtration,DFA 'Cross Connect' Fuel Lines,
No limit, I have 8. 1 in my truck ignition, one in the center consol, one in my wifes car key ring, one on my dads key ring, and 4 spares in my wifes jewelry box. All are programmed and ready for action.
2000 Excursion 33,500 miles and counting!
Banks Big Hoss LVL 4, Banks 6-Gun, Banks Power-elbow
Banks Big-Head Actuator (set at 25 PSI), Banks Quick Turbo, Banks Compressor Wheel, Banks 4" Exhaust system but straight piped!, Banks Intercooler, Banks TQ Convertor, Banks Trans-Command, Westin Nerf Bars
Ultimate Bull Bar, Helwig rear sway bar, V-code springs, 2 HELLA 500 Driving lights, 2 KC Dayliters, Lights mounted on a custom home fabricated mount on the Ultimate Bull Bar.
285-75-16 MT Tires, Visor over windshield and rear air dam over hatch. Custom painted monochromatic in factory dark green. Amsoil 3000 Synthetic engine oil With AMSOIL EA Synthetic Filter and Amsoil Synthetic differential lube. Warn manual hubs.
I'm ready for a hook at the next truckpull!
I wish i could get away with that - my wife actually wants real jewelry!
I wish i could get away with that - my wife actually want real jewelry!
With the PATS system the Excursions use the maximum number of keys is 8 according to the Ford PATS Job Aid that I have. I have never seen anyone with this many keys or more so this information is only from Ford.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
FMT
Yes that is correct or 7 plus a pats bypass for a remote start since it counts as one key if it is coil on the ignition, about $35 from Ford and will work with varius units. Or a pats key end in a box, (not recomended as I think this is to easy to use as a by-pass and hot wire the truck)
Just adding that your remote start by-pass must be added to the key count.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
As others have stated, no limit on PATS keys. For the fobs, 4 is the limit.
John [img]/ubbthreads/images/graemlins/smile.gif[/img]
Stand corrected. I guess I should have said, no practical limit. [img]/ubbthreads/images/graemlins/grin.gif[/img] Who needs more than eight keys anyway? (My wife. [img]/ubbthreads/images/graemlins/biggrin.gif[/img])
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
FMT
Bruce
Bruce, please explian......I was going to have a Viper alarm installed with the remote start, but I did not like the idea of an actual key being in a little box behind my dash.
So there is another way???
Shure is! Don't have the part number gave all that paperwork with the old X
However just go to your best parts guy and ask him to look up the cost and accessories for the Ford Gold alarm system made by CODEALARM and it will list (or did) a little black box a bit bigger than an IceCube that has two coil wires comming out of it that go to a coil that goes around the lock cylinder (going on memory here) you have to remove lock cylinder (easy with a key) and the cover(s) then slide the coil wire over the lock area.
what the coil does is when acctivated emits a signal like the static chip in a pats key except it is turned on by your alarm box during starting only.
Since it came with no instructions and I could not find any for codealarm I had a regular $2 key made that would work the lock and then "trained" the ECM to the black box by just jumpering power to it till I had it working with the dumb key and the black box/coil combo. So now the ECM just thinks it's another key.
I think the power wires were black and red and I am thinking the black was positive and red negative (backwards just to be sure the average guy could not get it to work I guess)
I do recall my system had a grounded output during starting for the relay or the PATS or other sytem bypass so I put the other wire (black????) to the hot wire for the PTO aux wire that I used to power my guages. A 10 amp isolated wire as I recall and it is near the trailer harness hook up.
What year is your X I will have a FORD Elect Manual for sale as soon as I order a new one from HELMS. Just used it last night for some add ons I was doing in the over head.
I think I paid like $35 for the box and coil thingy
Hope this helps some
You are correct in being concered; if someone knows you have a remote start and assumes you have a key in the box they are off and running.
Even if you cut the key part off all they have to do is hold the pats part of the key next to the switch and pop the lock and turn the switch and it will start. At least with the coil thay have to get past the wiring hook up and fake that out, or trigger the remote start wihout the fob. Chances are they may tear up a few thing but will give up and go on to the next one.
Just my thoughts any way.
Possibly FMT can give us the number for that little black box or anyone; I am sure I am not the only one to use one of these or some one with Ford Dealer installed one shoud have it as well. [img]/ubbthreads/images/graemlins/smile.gif[/img]
It will work with any unit that has an output for a antitheft key system.
As I recall it is not a typical ford number, just a number like 123456
Bruce
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
