How much of a drop hitch/drawbar for 4x4 X? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 05-28-2002, 12:15 PM Thread Starter
I might be towing some stuff in the near future and wanted to get a drawbar. How much of a drop do I need for a stock 4X4 X - 2"? 3"? 4"? I've done some looking around at Walmart, but they only seem to offer them up to a 5,000# rating. I'd like to get a 10,000# rating to match the hitch. So, if you've got one like that, where did you get it? One last thing, what is the standard size ball that I should put on it?
I think that does it for now.
Michael
P.S. the price you paid would be nice too.
, SCMT Max Tuner, Diesel Innovations 4" exhaust, 3 pod A-pillar w/ VDO Vision boost, pyro & Trans, AIC, Baldwin bypass filter, ATS Ported Compressor housing...See my mod pictures
1995 Camaro Z28 K&N FIPK, Throttle body Airfoil, Jet-Hot MAC Headers, Borla SS 3 exhaust /w bypass, 3.5" Aluminum driveshaft, 4:10 Gears, B&M Ripper shifter, Accel 300+ ignition, Accel SpiralCore wires, Shift light, 100hp Nitrous
<font color="red"> FOR SALE! </font>
PSDExcursion is offline
post #2 of 5 (permalink) Old 05-28-2002, 12:42 PM
Re: How much of a drop hitch/drawbar for 4x4 X?
Lots of question and I sure do not have all the answers. But here it goes, I tow a few different trailers and at this time they are fairly light and small. The key is to have the trailer sit level. I had several draw bars but always was switching them around to find the correct one. I finally gave up and bought an adjustable height draw bar. Price ?. Bought it at Wal-Mart. Price semed fair for the quality. It is rated at 5,000 pounds/500 pounds. The factory receiver is rated at 10,000 pounds or more (depenging on the year and the fact that Ford just changed the label) only if you use a weight distrubition type hitch. As far as ball size, you need to match the trailer. Usually; 1 7/8", 2" or 2 5/16". Depends on the weight of the trailer. Draw bars are available in different size shanks. 3/4" and 1" are the most common I believe. The higher the size, the more capacity. You must make sure the draw bar, ball and receiver are atleast rated for the load of the trailer.
Hope this helps,
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
post #3 of 5 (permalink) Old 05-28-2002, 11:11 PM
unless you have changed your setup since the pic it looks close to mine and towing my 8x16 tandem carhauler I use a 4" drop and it is perfect for the trailer I have.( it is a 2") ball.
1993 Freightliner FL 70 GVWR 25,640lbs. crew cab c8.3 cummins alison 3060p 6speed auto with hauler bed "Now were serious about towing a heavy load".
2005 F350 4x4 C/C LB Dually Lariat TowBoss--sold
2004.5 dodge CTD- no tow & had to go
2005 KZ 43ft New Vision Toy Hauler 3 slides & 14' of enclosed garage
2007 Mercedes Benz GL 450
1956 Willys DJ 2 Wheel Drive(long term project)
1951 Willys M38 (on going project)
Richie_Rich is offline
post #4 of 5 (permalink) Old 05-28-2002, 11:15 PM
forgot on the lbs rating for what you ask 10k it would more than like not be a drop type and instead the type with torsion bars or a weight distribution type.
post #5 of 5 (permalink) Old 05-29-2002, 06:33 AM
Try a Putman 12" drop hitch it can go up or down 12" with a interchangable ball mounts you just buy how ever many differnt sizes you want and mount the ball to it and then its mounts to the drop hitch with 2 pins.
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission FASS and ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:30s ARB air lockers front and Dana80 rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
OneUp ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
