Old 10-06-2007, 10:37 PM   #1 (permalink)
how much lift and what size tire is this?
http://cgi.ebay.com/ebaymotors/ws/eB...m=160165635739
How much lift (if any) do you think this truck has? I kinda like the look of this truck and since I need new tires anyway, I was thinking about this type. Any good/bad experiences with BFG A/T's?
James2 is offline
Old 10-07-2007, 01:10 AM   #2 (permalink)
FamilyRide's Avatar
Re: how much lift and what size tire is this?
No lift. Just looks like 285's.
BFG's are very rare, hardly any one the road at all. [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Obviously I'm kidding. Probably half the 4x4's on the road that aren't OEM tires or huge lifts are BFG's. Although I considered going to BFG's in a load range e this time, I stuck with and prefer Bridgstone Revo's. Awesome wet road traction and no hydroplaning for one, but really awesome traction in any condition. Got 48k out of the 1st set.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 10-07-2007, 04:23 AM   #3 (permalink)
Thanks for the input. I've been looking around at the tire characteristics, and wet road traction is good for me. I get lots of rain here (about 130" per year), but no snow. I'll check out the revo's. I would like load range E if I can, although it might not be necessary. I haven't done the math yet.
Maybe the reason I was drawn to the BFG's is because I see them often? I see alot of swampers and mud terrains, but I do mostly on-road driving and not much heavy off road.
James2 is offline
Old 10-07-2007, 11:28 AM   #4 (permalink)
Had two sets of 295/75/16 on the F250.
First set got 80K miles on all four tires.
Second set had a blow out at 30K and a side wall puncture at 50K, the original two lasted until 70K miles.
Wanting a change put a set of 265/75/16 Ravo load range D on the X and a set of 295/75/16 Nitto Terra Grappler on the F250.
The traction is hands down the best with the Nitto's. The BFG's are great at spitting rocks.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 10-07-2007, 03:04 PM   #5 (permalink)
FamilyRide's Avatar
You can get Load range E Revo's but not in 285's. BFG now has them in 285's.
Even worn (and they still had a lot of tread left when I replaced them) the Revo's didn't slip on wet pavement and no hydro-planing. Simply an amazing tire.
The only complaint is that they do get louder with miles. Mine are on OEM wheels so they are slightly bulged so they don't wear like I'd like them too though. And they will pick up rocks pretty good. They spit them out, but I often just walk around picking smaller rocks out of the tread.
It's the wet road surface traction that is probably the primary reason I stuck with them again.
Old 10-07-2007, 11:38 PM   #6 (permalink)
I'm going to run factory wheels too, so I guess that's a consideration. Has anyone ever run narrower tires than stock, like a 235/85-16E? Just wondering. I have six almost new tires sitting outside. I think good wet weather traction will be a key consideration for me.
James2 is offline
Old 10-08-2007, 12:51 AM   #7 (permalink)
FamilyRide's Avatar
265's already look too small. 285's look right. I wouldn't go smaller just for the aesthetics. That's what's important right? [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Old 10-08-2007, 04:45 AM   #8 (permalink)
Does anyone know what model the six-hole aluminum wheels were available on (the six round holes, not the Ltd version)? I didn't see them listed in the 2005 sales brochure. This truck is an XLT version, and the sales brochure shows the 8-hole version.
James2 is offline
Old 10-08-2007, 06:01 PM   #9 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: James2</div><div class="ubbcode-body">I'm going to run factory wheels too, so I guess that's a consideration. Has anyone ever run narrower tires than stock, like a 235/85-16E? Just wondering. I have six almost new tires sitting outside. I think good wet weather traction will be a key consideration for me. </div></div>
I have new 235/85-16 Bridgstones on my Ex now and they are fine. However.......I have a small lift on it and am about to pull them off for something alittle bigger. I have 2 sets of rims and tires for it now ( 8-hole aluminums, Limiyted "D" series, the Bridgtone 235/85-16's and a set of 255/85-16's). I'm gonna keep the 8 hole rims and the 255's and sell the limited wheels with the 235's.
Anyway.......the 235's look fine on a stock EX (no lift) but if you install any lift a little larger tire looks better IMO.......
Randy,
<u>Northeast, LA.</u>
00' Excursion Limited 4x4 7.3L, 07' Grill, Kenwood DDX7015 in dash DVD/NAV,DP F5 chip stk/60HP tow/80HP econ, ATS full guage pod, F450 springs front/F350 in rear, Donohoe 2" level kit, 285/75-16's, Bilstein shocks, Hellwig rear sway bar, Ball Buster Turbo, DI head studs, Forged connecting rods, Swamp's stage 1 injectors, ATS 5 Star torque cvtr, ATS Commander controler, ATS 4" exhaust, DMH electronic cut out, DI regulated fuel return, Hx hose, True Cool trans cooler, AIS intake, SX high volume fuel pump, Rotorpros rotors, boost relief valve, Sonnax valve, Transmision filter kit and some more under there I'm sure!!!
http://i34.photobucket.com/albums/d1...uck/MyEx-1.jpg
JDJHNTR is offline
Old 10-08-2007, 10:52 PM   #10 (permalink)
Thanks Randy for the input. Looking at your photobucket picture in your signature line. Those wheels are not factory, and those tires are larger than 235 or 255, correct?
James2 is offline
