Old 09-30-2007, 06:53 PM   #1 (permalink)
How too program auto door locks systems
Way back in 2001 someone posted a method on HOW TO Program door locks
I cannot find post but my 01 only locks when I click on door locks.
My recall is using a method posted to program door locks at owner preferred.
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 10-01-2007, 04:45 AM   #2 (permalink)
Stewart_H's Avatar
Re: How too program auto door locks systems
<u>To enable or disable autolock using the keyless entry keypad:</u>
Enter the five-digit permanent entry code into the keyless entry keypad.
Within five seconds of entering the code, press and hold the 7/8 button on the keypad.
Within five seconds of Step 2, and while holding the 7/8 button, press the 3/4 button on the keypad and release it.
Within five seconds of Step 3, release the 7/8 button on the keypad.
If the autolock sound is disabled, the horn will chirp once. If the autolock feature is enabled, the horn will chirp once shortly and then sound a second time with a longer sound of the horn once the above sequence is completed.
<u>Autolock Enable/Disable — Using the Ignition Switch</u>
Another way to turn the autolock off/on is by following this series of steps:
Confirm that the perimeter alarm is disarmed.
Close all doors.
Confirm that the ignition switch is in the OFF position.
NOTE: Steps 4 through 8 must be performed within 30 seconds.
Turn the ignition switch from OFF to RUN.
Press the power door lock UNLOCK button three times.
Turn the ignition switch from RUN to OFF.
Verify that the RAP module chirps the horn. This indicates that the RAP module is now in the enable/disable mode and ready to accept program changes.
Press the power door lock UNLOCK button one time to command the RAP module to toggle the autolock/relock feature OFF.
Press the power door lock LOCK button once to enter the command.
Verify that the horn chirps one time to signal the RAP module confirmation of the command. There should only be one chirp indicating that autolock/relock feature has been disabled. If one chirp is heard, followed by a longer sound of the horn, the autolock/relock feature has just been enabled. Return to step 10.
Turn the ignition switch to the OFF position to exit the enable/disable mode.
Exit the vehicle and verify that the RAP module chirps the horn once to indicate that a feature has been changed and that autolock/relock has been disabled.
The enable/disable mode allows the autolock feature to be turned off and on. On manual transmission vehicles, when replacing the remote anti-theft personality (RAP) module, the autolock feature must be turned off by using the enable/disable mode. The enable/disable mode is entered when the following series of steps is performed:
1. Confirm that the perimeter alarm is disarmed.
2. Close all doors.
3. Confirm that the ignition switch is in the OFF position.
Note: Steps 4 through 8 must be performed within 30 seconds.
I hope that's what you were looking for.
On a personal note, I wish my Excursion had the autolock function. [img]/forums/images/%%GRAEMLIN_URL%%/frown.gif[/img]
Stewart
1999 F-150 Lightning (work truck)
- WMS Wicked Engine Combo going in soon.
2000 7.3L PSD Excursion (wife's)
- AFE Stage 2, MBRP 4" SS turbo back, Beans 1.0 exhaust housing & WW, DP Tuner F5 chip, B & V code spring upgrade, Bilsteins, Hellwig rear sway, ITP Overboost Annihilator and pre-pump mod.
1990 Mustang GT 5.0 hatchback
- Stolen and stripped, waiting to be rebuilt and reborn.
Stewart_H is offline
Old 10-01-2007, 08:49 AM   #3 (permalink)
Ken
Ken1 is offline
» Sponsor Links
»Garage Storage and Cabinets
