Old 08-10-2008, 12:58 PM   #1 (permalink)
My Photos: (16)
Hvac Fan Stays On
Turn off ignition, blower motor stays on. Front control only not the rear.
Turn control to off. Fan stays on. Turn key forward to 1st postion then off fan turns off.
Or
same as above fan stays on then after 10 sec fan turns off.
Or
turn off ignition. Fan stays on turn control to off fan stays on,turn to anything left of off fan stays on..turn to right of off fan turns off.
All fuses are good and no other electrical problems noticed.
No codes showing any faults.
DUNC
Edit
Went for drive turned off the EX and now there is a clicking sound like a relay coming from drivers side in front of battery sounds and feels like the ABS pump. Clicking every 10 sec.
Still no codes showing up??
x
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
Old 08-17-2008, 07:22 AM   #2 (permalink)
My Photos: (16)
UPDATE
Did some reading and found that GEM could be the issue as a result of geting wet or damp. Removed fuse panel and GEM, inspected for above and found no issue. Problem went away the next day and has not returned??
DUNC is offline
» Sponsor Links
»Garage Storage and Cabinets
