Old 11-03-2004, 02:19 PM   #1 (permalink)
I am needing some new tires soon for the X...
Anyone have a recommendations for and Excursion 4x4 that will give a good ride and no tire noise but also will do a decent job in the snow?
1994 IDI Turbo CC 4x4
PPrash is offline
Old 11-03-2004, 03:58 PM   #2 (permalink)
Re: I am needing some new tires soon for the X...
I have used the Michelin LTX M/S on my Excursion and my other trucks withh great results. They are a little pricy, but not bad if you get them from COSTCO (they can order them) when than have a "coupon" sale.
Michelin also sells the same tire under a few different models for special stores - Wal-Mart, Sams, COSTCO, etc.
John [img]/ubbthreads/images/graemlins/smile.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 11-03-2004, 04:12 PM   #3 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
I bought Cooper Discoverer A/T's 285/75/16's about 20,000 miles ago and have been very happy with them. You can see them in my pics. That being said if I could have gotten a better deal on Bridgestone Dueler A/T Revos I probably would have bought them. From my experience I think the Revos pick up much less gravel, etc, because there tread is more closed...and also they are probably quieter than my Coopers even though they are not bad. Good Luck
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 11-03-2004, 04:36 PM   #4 (permalink)
FamilyRide's Avatar
Bridgestone Dualer AT REVO's hands down!
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 11-03-2004, 08:07 PM   #5 (permalink)
try these web page I have had good luck with them and ya can't beat the price.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 11-03-2004, 09:27 PM   #6 (permalink)
I got the BF Goodrich Somethingorother KO's. Weren't cheap, but they came with an off-road guarantee to not get stuck anywhere in North America (up to 3 times a year).
I have not been stuck in deep snow or axle deep muck and I have been in more than my share up in northern Ontario. They paddle right through snow and slop like a tracked vehicle. Fairly quiet on the highway, but they do have an aggressive tread pattern.
They are now just hitting 50K miles and I might get another 12K out of them this winter.
No Boundaries '01 PSD - U codes, Rancho 9000's & stabilizer, SCMT, Isspro EVA trio on pillar, BFG 285's, badges, Fabtech Desert Guard, PIAA 580 driving and pencil beam, dome override, ART brakes.....
edex2 is offline
Old 11-04-2004, 12:33 PM   #7 (permalink)
I second this notion. My X is almost as good in the snow in 2wd with the Revos as it was in 4x4 with the Firebombs. The ride is also smoother. Note: I have the 285s.
2002 X, 4x4, Limited Ultimate, 285 Dueler A/T Revos, Bilstein shocks, Edge mini-spring pack, F-350 4" rear blocks, Street Scene speed grill, Lund trim color bug deflector, Hellwig rear anti-sway bar, tinted front windows, Fram Sure-Drain
neilc88 is offline
Old 11-05-2004, 12:42 AM   #8 (permalink)
Yep those are the ones, about to buy my second set.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 11-05-2004, 02:32 AM   #9 (permalink)
Just got the 285 Revos and like them a lot. No noise and traction is good in the rain. Ride is SSmooth too!
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
Old 11-05-2004, 08:17 AM   #10 (permalink)
wow
I used to run the Michelin LTX's and had good results, but I thought they'd be too soft for the X. I bought the Nitto Terra-Grapplers, and have been delighted with them so far. Only 4000 miles on them, but they track beautifully (no wandering) and they handled very well in a torrential downpour - no loss of control even when I could hardly see through the rain! If I had to replace tires again for any reason, they'd be my first choice.
Wayne
2004 X Limited. Medium Gray Metallic, 4x4, 6.0L Diesel, DVD, LimitedSlip Differential, HD Tow Group, Transfer Case Skid Plate, Radius Rods, Remote Starter, Magnum Hitch, Nitto Terra-Graplers, Running Boards Removed, Large Payments.
wow is offline
Old 11-05-2004, 10:42 AM   #11 (permalink)
CHPMustang's Avatar
We just got the Pirelli Scorpion AT's but only have had them on wet roads and they track well.Snow testing comes this January when we venture the Rockies and Sierra Nevadas.
With the agressive tread pattern I have no doubt they'll traction very well.
Check my photo album in my signiature for some photos of them installed.
The handling of the tires is excellent I must add. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 11-05-2004, 07:03 PM   #12 (permalink)
We have the Nitto's and they are a nice tire, but I would not buy them agian. To soft for this rig, they have 15,000 miles on them and they are 50% worn out. The tire shop said they have had 3 sets come back worn out at 20-25,000 miles and all have been rotated at 4-5,000 miles. The next tire we buy will be the REVO or the TOYO.
2004 EB 4WD PSD X, AFE intake, Juice Chip, 285 NITTO'S, Weld Velociti 8's
kent65 is offline
Old 11-05-2004, 07:12 PM   #13 (permalink)
elw
Anybody have any comments about this tire? Dunlop Radial Rover RVXT It appears it is available in load range E
If you ain't rubbin you ain't racin..
04 04 6.0L 4X4 Black Limited X. ordered 10/11/03 Born on 11/3. Home 11/25. Fully functional PI , MBRP, No throttle plate, Carlite Superduty Logo, TAG, Air Lifts (both ends), Firestone single guage 2 needle control, Autometer Cobalt’s/w additional dimmer in 4 gauge A-pillar, aFe, Hadley, Famm, Bilsteins, ART, In dash Jordon, ZieBart, SUVlights(2), Silverstars, UltiMat, EZ Change, Studs, EGR Fix. FOKISD Member. NRA Life Member.
My kids tell me they don’t think I’ll ever grow up. Damn I hope not, I plan staying a kid forever.
elw is offline
Old 11-05-2004, 07:56 PM   #14 (permalink)
i always liked the BFG AT's they are real good in the snow and dont make any noise.
Sukhi
2000 Ford Excursion 4x4 7.3l Powerstroke Diesel.
8" Edge suspension lift. Donahoe Racing Res. shocks. Deaver Leaf springs. Fabteck 3.5" hangers. Mickey Thompson 38x15.50r20 MTZ's. 20x10 Jesse James Lawless 8 rims, AFE Stage 2 intake. Auto-meter guages: pyro, trans, boost. ART slotted rotors, performance friction pads. 4" turbo back SS straght pipe exhaust(no muffler), DP-Tuner 4 pos flip chip 80/100/120/140, Billet grill, Apc Projector head lamps. Clear corners, AMP Research power steps.
my other trucks
1997 GMC Suburban 4x4 6.5l Turbo Diesel.
1996 Dodge Ram 2x4 5.9l Cummins Diesel.
1997 Chevrolet Tahoe 4x4 6.5l Turbo Diesel.
1990 Ford Club Wagon Van 2x4 7.3l Diesel
1989 Chevrolet 1ton Van 6.2l Diesel.
2003 Chevrolet C4500 6.6l Duramax Diesel/Alison
powerstrokex is offline
