I am a new owner of a 2000 7.3 diesel excursion with 142,000 miles on it. This is not my first diesel, I have owned my 99 f350 7.3 for over 7 years and have a lot of experience with the powerstroke. But have a few questions about this one.
first none of the automatic door locks work, all have to be unlocked manuelly. Was told I have to replace a sensor in every door? Is that true?
Also Its throwing a code, will a edge module work as a code reader?
Anything I should look out for? I know most of the Powerstroke things but dont know much about the chassis and cab.
Does your truck have a Key FOB? And does it work? I have not had problems with the locks on my Excursion, but I did have an issue with a previous Suburban. The door lock buttons did not work, but the Key FOB did. I found that the door switch panel was not getting power. I ran a new power line to the Drivers door and into the proper connector on the door lock switch and all was fine. Never had another problem. So, in your case, I would check to see if your door switch is getting and power...
Pretty classic problem, you can buy aftermarket actuators cheaper. They run in a serise so it could be the drivers side front. A good auto elec guy can tell you if it has to be all. Does it have a perf mod like a chip or prog.? I have an Edge programer and it was the only one that did not screw my truck up, I do get a check engine light if I really stab it with a trailer usually going up hill....it is an over boost code, I went and paid the $40 to find this out and it shuts off if you disconnect the batteries for a second or about 20 cycles of the key. If it has something I would take it out and get a baseline, drive it and then reinstall the mod. I tried 4 and had some that barely idled to lights flashing on the dash and all heck breaking loose with gages flip flopping. The chassis is different, the 7.3 is solid but the elec and mechanical of the truck can be a problem. I have 192K and I have not had any gremlins or weird things happen. Heck I am just replacing the batteries tomorrow, thats with lots of draw from lighs and constant drain till dead playing the stereo while working outside...thank god for those jump starter boxes....
2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
I have had trouble with 3 or 4 between the X and the 350. I found replacements for around $40.00 dollars, if I remember correctly, I ordered them online.
Some else wrote:
Here you go
It has been a couple months so I might not remember the exact size sockets but here are the directions.
On the bezel where your window switches are, pull straight up on the front, then pull towards the front of the truck, this will remove the bezel, unplug it and set aside. There are two screws that hold the door panel on, one is under the bezel you just removed and the other is under the courtesy light cover. After you remove the two screws lift straight up on the door panel and remove. You will have to remove the plug for the courtesy light. Now peel back the sound proofing about 1/2 way, be careful as you want to reuse this. Now get a flashlight or droplight into the door area. You can now see the backside of the door handle. There are two bolts that hold the door handle on, one you get to with a wrench from inside the door and the other you need to remove the rubber plug on the side of the door and use a socket and extension. Disconnect the two metal rods that hold the door lock in and set the lock assembly aside. Now you have a clear view of the actuator, if you look at the new one you cane see a plastic spring lever that must be depressed to release the actuator. Using a small flat blade screwdriver reach in and depress that plastic bar, with the other handle wiggle the actuator and slide towards the outside of the door. If you have big hands this can be a little tough. Once it slides out simply unplug and replace in reverse order. You want to make sure that the rod on the actuator goes into hole on the lock assembly. This sounds complicated but it will all make sense once you are in there. PM me with any ??? The new actuators are much stronger than the old ones.
Kevin
Another wrote:
WARNING: The following is long winded, but if you want your PDL's to work again WITHOUT spending any $$ read on.
I finally got tired of my non-working PDL's and decided to tear into my truck and find/fix the problem. There has been many discussions about possible issues and I have concluded that the majority of us are seeing actuator motor problems and not relays, switches etc. Ill start by saying the problem I have had is that when I hit the switch, the locks attempt to move and after repeated attempts, the signal appears to get weaker and weaker until nothing....I assumed relay or switch.....NOT THE CASE!
First I started by testing the signal at the harness plug to the actuator. Perfect. No issues here. Next I completely removed the actuator/lock mechanism and bench tested them with 12V..Here lies the problem. The actuator acted the same as when in the truck. First I did a thorough cleaning of all of the mechanism so it works freely and still had the same results. Here's where it get's tricky. These things are built so that they are NOT serviceable. I had already decided that they were going to need to be replaced, so I decided to break them open for closer inspection. It comes apart relatively easily, but appears that It cannot be put back together once apart. I drilled out two small rivets and then pried the case apart. As you pry the case apart you'll notice these small little plastic rods protrude up through the case cover. These rods are then "mushroomed" with heat through the upper case and then sealed with some kind of silicone. When you pry apart the case the "mushroom" head breaks off and the rod remains. You can dig out the silicone and mushroom head with a pick. It comes out very easy. Inside you will find a very small motor and some gear mechanism. I believed the problem at first to be worn brushes or dirty commutator contacts in the motor itself. You'll have to bend two little metal tabs out and pull off the brush housing on the back of the motor. I cleanded the gunk off the brushes and took 1500 grit to the commutator contacts and reassembled the motor. The motor worked, but if you applied even a slight amount of resistance on the armature, it would stop the motor. It should have been WAY stronger than this. I was stumped until I looked a little closer at the inside of the plastic brush housing. Inside you'll find a small, thin rectangular (thermal resistor relay, dodad, thingamabob??) pardon my ingnorance, but I'm not sure what to call it. All I know is that this little part is what keeps you from burning up the motor, should you continue to press the switch once the lock has been actuated. It appears that this thing wears out over time and will not allow enough signal to get through to the motor to make it work. THE FIX. I am cheap. Since I had done so much work up to this point, I decided that I would go a little further and try to make it work without spending the $$. I have better things to spend my money on than actuators. I took a small piece of aluminum foil and wrapped the "thing" voila! Perfectly working motor! I sat there and operated the thing for 10 minutes including one or two times stopping the armature and holding down the switch to see what would happen. The motor builds heat, but not much. Not enough to worry about. Now that I had a good working motor I decided I would try and reassemble the unit. The problem is you cannot glue the unit together as there is a rubber gasket around the perimiter of the case and if you tried to glue the rods into the case, you would not have enough pressure on the two halves of the case to keep the gears in place (these things actually apply a great deal of torque on the case) What I decided to do is completely break off the plastic rods flush with the bottom side of the case and then drill out the bottom case and screw it together. This worked perfectly. You'll need screws that are the same diameter as the holes in the top of the case to keep it from "wandering". Also the screws should not protrude through the back of the unit as some of the mechanism has some pretty close tolerances and a screw sticking through the back would not allow some of the mechanism to work (this can be remedied with a decent set of wire dikes or a hacksaw). I know all of this is hard to picture, but if you do decide to try this fix, you'll see what I am describing here. The locks are back in and working flawlessly.
Best Regards,
2K Excursion Ltd Burg Auto, 146k 2K F350 DRW Lariat 6spd CC White/tan, 226k Late 98 (04/98), WHT F250 Std Cab 6 spd, 310k
Thanks, No chip or programer, this is my wifes truck and not going to go crazy...........yet. Just looking to do intake, exhaust right now. I found that one of the codes it throws is a Glow plug code so I need to replace thoses, also it throws these codes P0683, and P1670-EF. I have a book that lists the codes but got to find it.
anything else I need to know about these Excursions?
The GPs are a common code. Be careful on the exhaust, they work for PU trucks but thats because most of the truck is exposed, with ours being closed up there is a real droaning that occurs, kind of like harmonics and it will drive you out of the truck like a mouse with one of those high pitched repellers....you can do a search here but if your wife is driving it she will not be too happy with the noise. I have wanted to do this but am affraid I will not be happy. Overall the X is a good truck, I have had -0- problems in 192,000 miles and am just replacing the batteries now, it does not drip a drop of anything and has never left me on the side of the road, even a bad alternator went 300 miles until the batteries died and shut the fuel pump off.
Tyler
I think you are going to need a glow plug module. I'll bet if you ohm the glow plugs they all come out reasonably good.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
Search door locks fixed. There is a very easy sand free solution to the door locks.Save the rear for last and bevery careful on it,the rest are easy, just dont stop its harder tearing out then going back!
Great truck- you'll love your Ex! The wife has 165k on it and it's and going strong. No major expenses- just do the maintenance, and she'll treat you right.
2002 Excursion 7.3
1999 F-250 SC SB 4X4 auto
