Input wanted: Rearching front springs vs. changing
I'm looking for some input from people with a little knowledge on the front springs on the Excursion.
I have not had a ride in an Excursion with updated front springs, so I do not know how much ride harshness is increased, if any. I have thought about the possibility of having the front springs rearched to gain some spring travel, and eliminate the dreaded bottoming out. There is a company locally that rearches springs, and I have had it done on our race care, but never on anything big like the Excursion.
As the Excursion in my mom's, I would like to maintain the current ride quality, minus the bottoming out.
The biggest worry I have is going thru all this effort just to have the springs lose their arch over time.
Any thoughts from the spring Guru's?
Am I wasting my time?
Thanks in advance.
Dave
'99(02/98) 250 4WD, PSD, 6 Speed, LuK, EC, SB, AFE Stage II,Modified stock muffler, Hutch Tank Mod, Pre-Pump mod, JNB regulated fuel by pass system from ITP, Harpooned tank, 6 disc CD changer, Evens NPG from Bob Riley, 203 T-Stat and Billet housing, 15.23 MPG Lifetime
'95 Dodge Cummins, 2WD, EC, LB, DW, LEER top, Auto/DTT TQ Converter and some other goodies to make the tranny Dodge should have built, BHAF, 90 HP plate, 3,000 rpm Governor spring, 4" turbo back, Evens NPG, Gauges by DPP 17.7 MPG Lifetime
01 Excursion: Magnaflow turbo back from Diesel Innovations, Evans and 203 stat from Bob Riley. Helwig rear swaybar. Cow Car Racing My Photos
Never argue with stupid people. They just drag you down to their level and beat you with experience.
Re: Input wanted: Rearching front springs vs. changing
I have considered this, I am just feeling out options right know. One concern I have with that is spring sag that has already occured, and thus less travel left in the suspension. These are the types of things I hope to get answers to.
Since my parents don't currently tow anything heavy, this may be the best option. I'm just looking for feedback on the best option.
Thanks for the input
Dave
I installed "U" codes on my 03 X . Install was not too bad with a few friends to help out . Ride did not suffer but just the opposite as you do not bounce off the bump stops after the new springs are in . I found my springs off a new 04 superduty that was getting a lift kit and was able to bargain for them for $ 50.00 . Have not seen anybody here that has re-arched their springs . If you have to go thru the trouble of disassembling the front end either way then I would just get the "U" or "V" codes . BTW, Bruce1954 is the guru on this subject and I am just passing along my .02 .
I have considdered this for the 05 since I have a set of 02 Gs sitting in the back of the shop but since the Gs sag (Vs do also after 100K) seems like rearching them is asking for trouble. I need to start looking for a set of U take offs to put on the 05. I have just under 5K Baught it on May 27th on it and it is starting to bounce up front. And the front rotors are starting to warp, wonder how I will fix that [img]/ubbthreads/images/graemlins/wink.gif[/img] after my two free turnings at the dealer, will do one at 10k and one at 19.99999K
For what you want hunt down a set of Us and put them on assumming it is a PSD if V-10 then the Ts will work but are hard to find. Us and Vs are the most common.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
I too considered re-arching. But with all of the info on this site giving us specifics on spring rates, ride height & load capacity. I just bought what I wanted and installed new springs. No guessing and no messing around trying to get what I wanted.
Keep us updated if you go for it, you could start a new trend of re-arching old springs instead of buying new ones. We will need specifics on how much the springs get arched for others to copy and really benefit from your experiment.
Heck, if you supply enough info for others to replicate, it could be called the Dave Mod or the Grinder Mod just for your trouble.
__________________ My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
If I did re-arch, I think I would try to find some springs off another Ex that had a lift put on, no need messing up my moms springs.
On the V's, it sounds like it is not giving a harsher ride, is this correct?
On switching to V's, I am pretty sure I could come up with a set from our local Schwab since I know the manager.
It is very tempting to try the re-arch. May even be able to do it without Mom finding out. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Thanks everyone for the insight. I appreciate it.
Take care,
Dave
Guess I should give a little info on the Ex since it is not in my sig.
'02 limited PSD, 4x4. 3.5" dp, 4" exhaust from DPP, Regulated return from ITP, Hutch tank and pre-pump mods(intank pickup was crushed on the bottom of the tank from the factory, screen was popped out. Pickup was almost inside out [img]/ubbthreads/images/graemlins/eek.gif[/img]) AFE stage II on shelf waiting for custom airbox.(bought replacement filter not whole kit) er, actually I am testing the AFE on the F250 to make sure it works until I get the airbox built, but please don't tell my mom. Helwig rear sway bar, Bilstien shocks. OilGaurd EPS-20 bypass filter. Landyought RR on list.
There are three choices, live with it (not an option), add-a-leaf for the front, F350 block in the rear, or new springs, like V or X codes (may as well lift it) and a block to level the rear. I used V codes, a 1.5" add a leaf and a 4" block in the rear. It took all day but was straight forward. Worth the 3". This or a nice soft ride 4", that is what I want. Sprngs all around, no blocks. I forgot one more, a shackle kit but that uses the same spring configuration.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
If you try Neil's suggestion and it seems to work, you might consider replacing them with 2003 Ex front stops. They are softer and shorter than pre-2003. Then, when you do occasionally bottom out it will be a lot less violent. They also are a good choice with "U" codes and up.
Plenty to think about. I am glad to hear that V's do not harshen the ride. Then I guess ride hieght fron to rear is a consideration also. I have read some of the posts on this, and am mulling the different options there.
Thanks everyone.
Dave
or call deaver springs and tell them your problem, they can make a spring with a little greater height but made up of multiple thinner springs for a better ride. my springs are made by deaver for Donahoe Racing and they have a better ride then stock. I tried re arching springs and they rode like snot
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
