I bought the AC valve from www.dieselsite.com and installed it yesterday. I installed it in the line from the rear heater core before it goes into the "T". It came with a "T" for the vacuum line too. The only thing I needed was about 6" of larger vacuum line to install onto the factory valve. The installation only required one cut on the truck.
Now, when I turn MAX AC on it closes the factory valve plus the new one which stops the crossflow between the front and rear heater cores.
I don't have a thermometer for precise readings, but the MAX AC is definitely colder.
My next step is to insulate the charge lines from the compressor to the evaporators.
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
You got on it pretty quick [img]/ubbthreads/images/graemlins/smile.gif[/img]
You just need the digital thermo probe for the dash vent [img]/ubbthreads/images/graemlins/cool.gif[/img]
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
I don't know when I'm going to use all this massive cooling power though. It's only 73F outside today and isn't supposed to reach 90F until next week. I guess I should be thankful.
I am assuming you ment the suction line, (the cold ones)
We need all the cooling we can get on the "charge lines" from the condensor to the evaporator.
I don't think you will gain much but it may be worth a try you might try some of that foam pipe insultion from your home improvemnt store.
Some suction lines I have seen do have an extra layer of insulation on the hose portion not sure I have seen much on steel tubing but it would make more sense to insulate that and not the hose.
Let us know
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Let us know
Bruce and all,I've pretty much have outdone myself with the AC outside of installing a second compressor for the rear [img]/ubbthreads/images/graemlins/grin.gif[/img]
Here's my latest Photo Album with the AC mod work completed.
I started on it all in early summer 2003 and just wrapped up the compressor work a month ago.
The results have been outstanding! [img]/ubbthreads/images/graemlins/cool.gif[/img]
-Bill
I checked my chestnut 2001 psd x and I have this valve but
no vacuum connected to it. There is no lose vacuum line anywhere
around. Does anyone know where to connect this to? I know the
max position ac switch closes the damper door-where is this vacuum line. Is it the one just rearward of the condenser?
I havn't checked for the valve, but I realized last night that my PSD EB 'X with climate control doesn't have a 'MAX AC' setting. It has the 'MAX AC' behaviour when set to 60F (which is what max ac did on my old navigator) ... but no MAX AC button.
