Old 04-05-2002, 10:38 PM   #1 (permalink)
Installed my AIC today
Not hard at all. I was able to tap into switched 12v from my gauge install, ground was the same way. Talking to Sail864, he mentioned to me to unscrew the OBD-II connector to get to the data lines easier. Went without a hitch. Looks cool too. [img]/ubbthreads/images/icons/smile.gif[/img] If you want to see a pic, click on the AIC in my sig.
Michael
2001 Excursion PSD Limited 4x4, SCMT Max Tuner, Diesel Innovations 4" exhaust, 3 pod A-pillar w/ VDO Vision boost, pyro & Trans, AIC, Baldwin bypass filter, ATS Ported Compressor housing...See my mod pictures HERE!
1995 Camaro Z28 K&N FIPK, Throttle body Airfoil, Jet-Hot MAC Headers, Borla SS 3 exhaust /w bypass, 3.5" Aluminum driveshaft, 4:10 Gears, B&M Ripper shifter, Accel 300+ ignition, Accel SpiralCore wires, Shift light, 100hp Nitrous [img]/ubbthreads/images/graemlins/crazy.gif[/img] <font color="red"> FOR SALE! </font>
2002 32' Keystone Bobcat 294BHS travel trailer
PSDExcursion is offline
Old 04-06-2002, 01:36 AM   #2 (permalink)
Re: Installed my AIC today
Please explain the tapping of the OBD II connector... Is it behind the connector? Or does it connect through the front?
I was worried about splicing the line to get the data lines connect, but if there is a easier, cleaner route, I'll go that way.
Picture would be nice if feasible.
StevenVA is offline
Old 04-06-2002, 10:27 AM   #3 (permalink)
Yes, please provide a detailed description of what wires were used, and where you tapped into them, etc.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 04-06-2002, 10:37 AM   #4 (permalink)
I will be doing my install in the next few weeks. I remember seeing some old post which were very detailed in how to do what, where and with what. I would like to add a plug to the wiring so I can uplug the AIC just like the trucks. Anyone do this?
Thanks,
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 04-06-2002, 10:44 AM   #5 (permalink)
I used saddle splices to tap into the data lines behind the connector. I've already screwed it back, but if I get time today, I'll take some pictures.
Michael
Old 04-06-2002, 10:46 AM   #6 (permalink)
JADFPE,
Why a plug? It's not like it's something you are going to take out. [img]/ubbthreads/images/icons/smile.gif[/img] However, if you want you can talk to Gene Louder, apparently he knows somewhere to get the plug in CA. However, you are going to have to splice that plug into the wiring harness anyway.
Michael
Old 04-06-2002, 11:24 AM   #7 (permalink)
True - I was just trying to make it look like a factory connection but I guess you are right. By the way, what is a saddle splice?
Thanks,
John
JADFPE is offline
Old 04-06-2002, 02:26 PM   #8 (permalink)
A saddle splice allows you to splice wires onto existing wiring. Stick one wire in, and it fits over the existing wiring, it has a blade that you squeeze down with a pair of pliers, which cuts through the insulation and makes the connection. Available at any auto parts store or hardware store. Now, here's the nitty-gritty of the connection makeup. This is taken from a post by JBKrab:
The EXCURSION does not have the connector to plug the APCM into. The connector consists of four pins that are connected to the PCM (Powertrain Control Module).
What we need to do is the following:
1. Connect the Tan/Red wire of the APCM cable to 12V Key Power.
2. Connect the Black wire of the APCM cable to Ground.
The remaining two wires are a twisted pair. (WARNING: THEY MUST STAY TWISTED EXCEPT AT WHERE YOU MAKE THE SPLICE OR CONNECTION. THESE ARE DATA LINES AND REQUIRE TO BE TWISTED TOGETHER!)
3. Connect the BUS+ Red/Blue wire of the APCM cable to the TAN/ORANGE wire from the PCM Pin# 16.
4. Connect the BUS- white/violet wire of the APCM cable to the PINK/LIGHT BLUE wire from the PCM Pin# 15.
That's all there is to it. Real easy once you get the OBD-II connector off so you can get to the data lines. The full post is here, but everything you need to know is in the first post.
http://forums.ford-diesel.com/ubbthr...mp;Main=117088
Enjoy,
Michael
Old 04-06-2002, 07:30 PM   #9 (permalink)
Michael - Thanks for the information. Depending on the weather on Sunday, the kids and of course the wife, I might be able to spend some time getting the AIC installed.
Thanks,
John
JADFPE is offline
Old 07-29-2002, 08:23 PM   #10 (permalink)
Just wanted to bounce this one to the top in case anyone was contemplating putting in a ford AIC. I followed the instructions listed two posts above and I am pleased to report that my AIC is now fully functionaly. Gotta love this site.
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 07-30-2002, 12:10 AM   #11 (permalink)
You can find the data wires easily if you remind yourself to look for a twisted pair. When I installed my AIC, I was unaware that the twisted pair was available at the ODB-II connector, so I went hunting for it in the huge wiring bundle under the dash. Stupid me kept checking individual wires for the right color code. As it turns out, there's only one (or maybe two - I was too excited to do any major verification) twisted pair in that entire bundle, so it's not so hard to find.
ptemplin is offline
Old 07-30-2002, 08:49 AM   #12 (permalink)
Glad to see that you are part of the few, the proud, the excursion owner with an AIC! [img]/ubbthreads/images/icons/smile.gif[/img] They are cool. With the Walker BTM and the idle at 1200 rpm, you sure get a pretty cool turbo whistle. I love mine...keeps the A/C frosty on even the hottest days. [img]/ubbthreads/images/icons/laugh.gif[/img]
Michael
Old 07-30-2002, 01:23 PM   #13 (permalink)
Michael,
Cochise here. Did you get your "AIC" form David at Diesel Innovations 713-948-9441? [img]/ubbthreads/images/icons/cool.gif[/img]
Click on address for quick connection cwillis@planetford59.com
Cochise Willis
Humble, Texas Good Ole' USA
Call me @ 281-319-9644 Fax me @ 281-319-9635
800-299-8791 X 9644
[url=http://www.planetford59.com]
Cochise is offline
Old 07-30-2002, 04:00 PM   #14 (permalink)
Yup, picked it up right after you posted that there were 70 available. (Hopefully he's giving you a commission!) What's a good idle speed to avoid wet stacking? I was leaning towards using the "Charge Protect" but didn't know if it was high enough. The other question I had was what voltage do people typically see in Charge Protect? I'm seeing 12.3-12.6. I guess I expected 14.7 or so from my gasser experience.
Regards,
Dave
2003 Kubota B2910
dmftoy1 is offline
Old 07-31-2002, 08:12 AM   #15 (permalink)
Cochise,
Naw, I got mine used for $200! [img]/ubbthreads/images/icons/cool.gif[/img] [img]/ubbthreads/images/icons/cool.gif[/img]
Michael
